Craigsti Posted February 12, 2012 Share Posted February 12, 2012 I was wondering were most people attach chains to on the motor when removing the engine I know there is a mounting pointon the front of the motor Thanks for any help Link to comment Share on other sites More sharing options...
6 Star Posted February 12, 2012 Share Posted February 12, 2012 There should be a little arch-shaped bracket on the bell housing on the rear of the engine. Use that and the bracket on the front you mentioned. Link to comment Share on other sites More sharing options...
mm88swrt Posted February 12, 2012 Share Posted February 12, 2012 i've usually always used the bracket on the rear of the motor for the motor mount bar. and on the front i believe it is the p/s bracket that has a hole on it for bolting a chain to it. just my 2 cents! throw a 4x4 in the mix and it comes out with ease Link to comment Share on other sites More sharing options...
man on the moon Posted February 13, 2012 Share Posted February 13, 2012 Not orthodox, but I've strung straps around the block cozied up to the oil pan to keep pressure off the heads, stuck a pole through both straps, put a friend on the far end of the pole, and counted to three. Light motor and easy to get out. Link to comment Share on other sites More sharing options...
MilesFox Posted February 13, 2012 Share Posted February 13, 2012 I like to mount the chain to the pitch stopper mount using the bolt through a link, and the other end to the p/s pump. I f you remove the p/s pup, you can thread a bolt thru the chain to one of its holes on the block. Link to comment Share on other sites More sharing options...
Indrid cold Posted February 13, 2012 Share Posted February 13, 2012 Not orthodox, but I've strung straps around the block cozied up to the oil pan to keep pressure off the heads, stuck a pole through both straps, put a friend on the far end of the pole, and counted to three. Light motor and easy to get out. yup..... Link to comment Share on other sites More sharing options...
987687 Posted February 13, 2012 Share Posted February 13, 2012 Not orthodox, but I've strung straps around the block cozied up to the oil pan to keep pressure off the heads, stuck a pole through both straps, put a friend on the far end of the pole, and counted to three. Light motor and easy to get out. A friend and I did this to get a junk yard motor out. Used seat belts out of the car and a driveshaft as the pole. Link to comment Share on other sites More sharing options...
