Question about pulling e82
i've usually always used the bracket on the rear of the motor for the motor mount bar. and on the front i believe it is the p/s bracket that has a hole on it for bolting a chain to it. just my 2 cents! throw a 4x4 in the mix and it comes out with ease :headbang:
Not orthodox, but I've strung straps around the block cozied up to the oil pan to keep pressure off the heads, stuck a pole through both straps, put a friend on the far end of the pole, and counted to three. Light motor and easy to get out.
A friend and I did this to get a junk yard motor out. Used seat belts out of the car and a driveshaft as the pole.
