No oil pressure at warm startup
use RTV ultra gray, a thin coat. you don't want globs of it to squish inside and get pumped around the engine.
crank seal.
oil pump o-ring. i'm sure shawn will help with this as well.
Yep - I forgot the Oring. Old ones will be smashed(one on each pump).
An oil pump has ONE Oring.
WHat I meant was the Oring on each pump (the one you're taking off and the used one you'll be installing) will both be squashed(no longer round) and old so neither will work well. And either will likely break when you try to remove.
It SHOULD just slide off. Both of my cars it slid off with little effort.
I tried to get an oil pump from a junkyard car and couldn't get the sprocket to budge to save my life. Pried at it for a few minutes with a 24" prybar, broke one of the teeth off, then gave up and found a pump on another car.
