Disable and remove AC
My Ac is toast.... hasn't worked in ages
and not really interested in reviving it.
What I would really like to do is remove
the compressor... I removed everything else..
This will require some kind of revamping...
I don't want to get into re-engineering the
alternator bracket..... Anybody have any
suggestions.... ?????:brow:
thanks, Micky
l re engenered the bracket
but just a tiny bit
used apiece of gas pipe as a spacer
and a (long)bolt nut washer to hold ti in place
is working fine
and l ran with out said contraption for a while with no ill effects
cheers
goat
thanks, Micky
If you search on recent posts in older generation here, there are pictures and more using factory parts to do it. If you don't have the said parts, a board member may be able to help you out with that.
Doug
You can leave the compressor in if you don't want to mess with rigging a new alternator mount. Just unplug the two wires coming off it so it doesn't come on.
I went the extra mile and took out the a/c lines and condenser. I left the evaporator, but you can take that out, too, if you want to mess with the dash. I used a hacksaw to cut the lines about two inches from the compressor, crimped the cut ends 'closed' in a vise, slathered the sharp bits with silicone to 'seal' them, and poured a few tablespoons of oil in the compressor (via one of the line in/out holes) to keep it from seizing up. Over two years now and running strong! The hour of labor and trash dump run beat the heck out of trying to modify a bracket for me.
Yeah, I unplugged it and ripped the accessorieds
out last summer... I was due to get that big
hunk of terd of the motor.... That thing has to
weigh 20 pounds. Anway... I picked up a 3/8"
inch black gas nipple...(I forget what size I got)
but the idea goat brought up I took to the next
step... Just in that I bought a nipple smaller than
what I needed in size. To this nipple I added a 3/8
black coupling... The coupling made it longer than
the desired size... Then I tightened the coupling on
to the nipple, this was done till it was the right size.
There is no cutting involved. AC unit is gone now.....
The only thing with this method is that there are
only three points of support. It causes the swivel
of the alternator to be bolted in while the other
two point are a little loose... It is important to
make sure the belt is straight. then the two
points can be tightened. then the swivel can
be tightened.....
I would like to think that this is a temporary
rig. till I can get the actual bracket from
an older gen car.
A welder and a little metal fab experience
could mod this very easily and use the nipple
concept. Just bolt it ... and then weld it.....
I any event.. this is better than having that
useless dead unit there.:headbang:
So car is running and
using the nipple concept
so the ac is not there anymore.
Works ok... belt is straight......
and I was able to use the same
belt(though almost at the end of
its adjustment). I would say
a new belt 1/2 in or 1" smaller
would be good....:cool:
