pinout on delco 21023479
I would need to see pics to be certain but you can buy a harness that will plug into the radio that is just like the one in the car
look for Metra part# 71-1858
http://www.metraonline.com/part/71-1858
it is the standard GM 21 pin plug, it was used from 1988 to 2005, you might even be able to get one from a junk yard for a couple bucks.
you will also want a gm antenna plug adapter and antenna if you are planning on listening to AM radio, or you can stick a wire in the antenna and get fm.
or if you want to solder connections on at the radio... these are the same as the saturn radio connections.
http://www.andylphoto.com/fiero/wiring.html
