rear main seal leak 97 ouback
I attempted two times to replace rear main seal on my 1997 subary legacy 2.5. First attempt was to seat flush and second attempt was to set in a little hoping it would find less worn shaft to ride on. I am about to attempt 3rd try as I want to get this right. I have noticed the aftermarket seals offers actually slight differences in seal size that contacts the shaft area, albeit less than 1 thousandth difference. Want to know if anyone has noticed this size variance and wether one size is more suitable than the other. I would think smaller would be better with my problem. The oem size is not something i could locate. The other option would be just to use a speedi sleeve but i am just wondering if maybe this difference in seal size is causing the problem. Separator plate is not leaking.
ok....i will go to dealer pick up oem and install. I am feeling better about this. I had no problems with aftermarket seals on the rest of this engine. From what i have read, this rear main seal is a bit tricky. I need to know at least the part is going to be reliable and in this case, oem seems to be the answer. By the way, the part is within a few dollars of aftermarket. Its a no brainer. Thanks for the advice. Will let you know how it comes out.
I'm going to attempt this copy and paste from RockAuto as I've been wondering what the measurements and differences were myself. These are for the OP's year, vehicle, and engine. Note the different shaft size for the Timken. .040" difference than the other two, with an .011" interference fit, seal to bore.
TIMKEN Part # 710235 MoreInfo2.png Shaft Size: 3.386"; Housing Bore: 4.055"; Seal Width: 0.394"; Seal Outside Dia: 4.066"; Seal Lip Material: FluoroElastomer; Housing Material: Steel; Max Temp: 400°F; Min Temp: -40°F; Seal Type: 320; Press Fit
$17.68Add Part AddToCart2.png NATIONAL Part # 710235 MoreInfo2.png Oil Seal; Silicone Seal, Counter-Clockwise-Spiral Design, Shaft Size=3.346", Housing Bore=4.055, Outer Diameter=4.064, Width=0.315"
$20.79Add Part AddToCart2.png SKF Part # 33861 MoreInfo2.png {Click Info Link for Alternate/OEM Part Numbers2144325000, 2144338010, 5047167AA, 806786010, 806786011, 806786040, MD150161, MD174940, MD359158} Outside diameter=4.0640"; Width=.315"; Shaft=3.346"; Bore=4.055IN
Note the diameter of the seal and the bore size, .009 interference fit seal to bore. OP got me wondering about this again. If going aftermarket a purchaser may have to measure the crank diameter?
Here's the link, I read "brown" seal it might be the SKF?
http://www.rockauto.com/catalog/raframecatalog.php
Doug
I had GD do mine and he used a PVC coupler or end cap against the seal and used a block of wood to hammer on over the coupler. he used redline assembly lube to lightly coat the seal too. hasn't leaked and it's been a year now. I'd ask him what diameter to use but he was very slow and meticulous, lightly tapping it into place.
I stand corrected after viewing the post, the variance is greater than 1 thousandth. This is purely a hobby for me but i would like to point out a correlation to my pharmacy practice. In pharmacy, generic manufacturers are allowed up to 7 percent variance from FDA approved brand name for the majority of drugs. I would think this variance in seal sizes would not be significant..... hopefully an engineer from one of these seal manufacturers will read this and explain in greater detail.
from previous attempts do you know for sure it's leaking at the ID or is it the OD? probably ID around the shaft?
might want to measure or gauge the crank for wear and make the sleeve decision based on that? i have never used a sleeve but i've seen other folks on the boards do it.
i've seen variances in size of the same brand and seal - Fel Pro EA82 crankshaft seal is one. I've used tons of them in the past but had one that would not seat normally as if the OD was too large. i took my time and eventually got it to seat and wedged in there - notably tighter than normal. as you can guess, it ended up leaking. next seal went in just fine. i've used Fel Pro's numerous times in the past without issue though? since then i've used almost exclusively Subaru seals, though i've used Fel Pro's on occasion and still have some in my garage.
one bad seal? quality control?
Eh, may be Gary.
What I'm wondering is why someone hasn't posted a picture using the bolts for the flexplate/flywheel, a spacer, and some kind of device/plate/bar to press these seals in. I've done that on other makes. Even using the old seal flipped around as the "pusher" on the new seal.
Doug
Eh, may be Gary.
Doug
I agree. But probably because you don't normally mess with these.
About the only "maintenance" item that causes more difficulties on a Subaru that it's worth.
Infact I'm trying to locate the exact tool you're talking about for old air cooled VW rear main currently.
off topic,
what do you call the sleeves that fit over the scarred end of a crank providing a new surface for the seal to bear on???
maybe the crank end is messed up.
Speedy Sleeve, Redi Sleeve, MicroSleeve, Quick Sleeve. Claim is they're good for 150,000 miles. I've used them, and they eliminate seal problems.
Doug
I wish I would have read this before I did my separator/o-ring re-seal. I used a OE main seal and was careful about getting it flush, yea, it leaks:mad:
Had you reviewed threads here before you did yours you would have seen where most of highly recommend NOT to replace the rear main.
Bummer. And now you can't even tell how deep it should go to seat unless you have another unmolested engine to look at.
I'm going to throw stop leak at it, see if it improves, it's not that much, just after high revs.
I pulled the engine for last time and realized that the after market seal did hold up after all. I discovered that the valve covers were leaking only after engine was not running and cooled down. I never saw one drop of oil coming out of these valve covers during operation. I think i just got over-anxious becuase of all the concerns raised about installing these rear seals. I would suggest for the do it yourself crowd that this rear seal is not as difficult as some would suggest. The key is to go slow and make sure goes in straight. As far as the valve cover gasket, I found this aftermarket gasket to not work well. I had to put washers on the valve cover bolts in order to snug it down further. It is totally sealing now and I thank you for your help.
It turned out to be the valve covers leaking only when the engine was cooled down....i never saw leaks out of the rear seal after the second repair but I just assumed it to be the causitive factor.....turns out it wasn't...all is fixed now and just for the record...the felpro aftermarket seal is working fine.
Did you oil the seal and shaft before installing? Putting the seal in dry can cause small rips or tears due to the significant amount of friction between the rubber and the metal. Also be careful what you use to 'push'. The mentioned PVC pipe of appropriate diameter works, or the fat side of a large socket (I think I used the same 22mm I used to push the pilot bearing into place), light taps a millimeter or less at a time all the way around. Each 'around' with the socket should be as even as possible.
As you have discovered, these are a p.i.t.a.--take your time and do it well!
ETA: I missed the post where you said it was the valve cover, not the rear main. Apologies, and glad it was an easier fix than you thought! That is always a good feeling (even if you did end up pulling the motor. Again.)
Edited by man on the moon
