SubieT Posted February 17, 2012 Share Posted February 17, 2012 About what should the mili; amp draw be on a 2000 Outback with nothing on and alarm not set. Thank you Link to comment Share on other sites More sharing options...
Cougar Posted February 17, 2012 Share Posted February 17, 2012 When things are in the sleep mode you might see around 15 milliamps. Anything below 30 milliamps is good. Link to comment Share on other sites More sharing options...
SubieT Posted February 17, 2012 Author Share Posted February 17, 2012 I have 270 milliamps darw now. Link to comment Share on other sites More sharing options...
Cougar Posted February 18, 2012 Share Posted February 18, 2012 That's too much draw. Somethings not right. Here is a link that will help you find the trouble. http://www.aa1car.com/library/battery_runs_down.htm Link to comment Share on other sites More sharing options...
edrach Posted February 18, 2012 Share Posted February 18, 2012 That's too much draw. Somethings not right. Here is a link that will help you find the trouble. http://www.aa1car.com/library/battery_runs_down.htm Wow. That's a link that should certainly be in the USMB Repair Manual. A fine write-up. Link to comment Share on other sites More sharing options...
danbennett2u Posted February 18, 2012 Share Posted February 18, 2012 Wow. That's a link that should certainly be in the USMB Repair Manual. A fine write-up. Yes that is a good link, I hate mouse over popup ads with a passion though. They make me avoid websites if I am on a computer I can not use adblockers on. Link to comment Share on other sites More sharing options...
Cougar Posted February 18, 2012 Share Posted February 18, 2012 I have 270 milliamps darw now. When you made the current test did you wait long enough to make sure the systems were in the sleep mode? Now that I think about it, that amount of current draw may be about the correct amount when systems haven't gone to sleep yet. Link to comment Share on other sites More sharing options...
SubieT Posted February 19, 2012 Author Share Posted February 19, 2012 Maybe I didnt wait long enough Ill try it again. I though I did. Link to comment Share on other sites More sharing options...
