mickytrus Posted February 17, 2012 Share Posted February 17, 2012 I am going to ditch the clutch fan. I ditched the AC... and alot of posts say One: the fan was for the AC.... and you can get a little more juice(power) out of this motor by losing the clutch fan..... However, I would really like to run an AUX. fan....... I am even thinking of running it off the Defrost switch the AC clutch used to use.... So does anyone have a link they could send me to a nice AUX fan. I would like to see if I could bolt it on the RAD.... Make it look OEM... I mean really I guess I could run an OEM fan.. (run two side by side) WELL, LET ME KNOW WHAT YOU THINK THANKS, MICKY:banana: Link to comment Share on other sites More sharing options...
man on the moon Posted February 17, 2012 Share Posted February 17, 2012 Try this: http://www.ultimatesubaru.org/forum/showthread.php?t=130121 Link to comment Share on other sites More sharing options...
mickytrus Posted February 20, 2012 Author Share Posted February 20, 2012 Thanks for the Link M.o.t.M. I finally got the car back together and running...(regasket job and timing belt) Now I can see how the car does without the Aux. fan.... It seems to be doing decent without the Aux fan... As was previously mentioned in earlier threads, the mechanical fan is for the AC.. (being that I removed compressor don't need it) ... So the electric fan was maintaining temperature kicking on momentarily (at idle) ; gauge a little below half........ It is February here so will have to see as the weather gets warmer... Motor is much happier :headbang:without the mechanical clutchfan... Link to comment Share on other sites More sharing options...
man on the moon Posted February 21, 2012 Share Posted February 21, 2012 With the AC out I have been doing well with only the clutch fan. I have the electronic one in the back but it's having it's own issues so I took it out and will replace it eventually. It doesn't get too hot here, though, or too humid. I think last summer it hit 90 a couple times :S Link to comment Share on other sites More sharing options...
l75eya Posted February 21, 2012 Share Posted February 21, 2012 Thanks for the Link M.o.t.M.I finally got the car back together and running...(regasket job and timing belt) Now I can see how the car does without the Aux. fan.... It seems to be doing decent without the Aux fan... As was previously mentioned in earlier threads, the mechanical fan is for the AC.. (being that I removed compressor don't need it) ... So the electric fan was maintaining temperature kicking on momentarily (at idle) ; gauge a little below half........ It is February here so will have to see as the weather gets warmer... Motor is much happier :headbang:without the mechanical clutchfan... I have done the exact same thing to Ben and he is exhibiting the exact same results. Little more throttle response, can hear the engine better now (no more WHIIRRRRRRRR), and the elec. fan pops on at just the right time to bring the temp down a little bit. Still think I as well am going to get an AUX fan to run in there just in case. Gonna work on pulling the compressor out when I do the waterpump soon... Link to comment Share on other sites More sharing options...
