Where to buy Auxilary Cooling fan.
I am going to ditch the clutch fan.
I ditched the AC... and alot of posts
say One: the fan was for the AC....
and you can get a little more juice(power)
out of this motor by losing the clutch fan.....
However, I would really like to run
an AUX. fan....... I am even thinking of
running it off the Defrost switch the
AC clutch used to use....
So does anyone have a link they
could send me to a nice AUX fan.
I would like to see if I could bolt
it on the RAD.... Make it look OEM...
I mean really I guess I could
run an OEM fan.. (run two side by side)
WELL, LET ME KNOW WHAT YOU THINK
THANKS, MICKY:banana:
Thanks for the Link M.o.t.M.
I finally got the car back together
and running...(regasket job and timing belt):clap:
Now I can see how the car does without the
Aux. fan.... It seems to be doing decent
without the Aux fan... As was previously
mentioned in earlier threads, the mechanical
fan is for the AC..
(being that I removed compressor don't need it)
... So the electric fan was
maintaining temperature kicking on momentarily
(at idle) ; gauge a little below half........
It is February here so will have to see as
the weather gets warmer... Motor is much
happier :headbang:without the mechanical clutchfan...
fan is for the AC..
I have done the exact same thing to Ben and he is exhibiting the exact same results. Little more throttle response, can hear the engine better now (no more WHIIRRRRRRRR), and the elec. fan pops on at just the right time to bring the temp down a little bit.
Still think I as well am going to get an AUX fan to run in there just in case.
Gonna work on pulling the compressor out when I do the waterpump soon...
