Just Finished the Weber swap.
Just put the Weber on I have had for a while, I traded a guy 100 rounds of 7.62x39 ammo or about $30 bucks. He had it on a BMW 2002. The jets are very close but I'm going to need the jet that controls Idle air circuit because I have to have the mix screw out 2 1/4 turns to get a smooth idle.
Took a total of 3 hours including road time to test it.
What an improvement even on an automatic car. :headbang::burnout:
  Loyale 2.7 Turbo said:
Great!
if you Click on my Avatar, you'll reach a List of my Writeups;
Scroll down and you'll Find the Weber Swap Writeup;
in the Last post are the Pictures of the PCV Setup on Weber Carbs.
Kind Regards.
I read it and it is a very informative right up. Just wish I would have read it before I bought the two piece adapter. I'm going to order that other adapter. I have to take the carb back off to put a manual choke on anyway so I might as well put a better adapter on while I'm at it.
Thanks for that great right up.:banana:
