Ford tempo spring swap help! Ea82
your tempo springs might be different,but I had to cut a coil off just to even get them into the strut.the coil you want is NOT progressive BTW.
This is 100% true. I forgot about that bit of info. I want to say Scott (xbeerd) had this same issue with this.
i had to cut the first coil off them, there would have been no travel they fit terrable, im not to sure i like the way they sit all crooked n ************, if i had to redo it id look for something else i ordered the cc852 like everyone said, n they look terrable, they work, for now :banghead:
