tallwelder81 Posted February 21, 2012 Share Posted February 21, 2012 HELP please!! i took apart my guts to swap to a shorter lift kit. but things came up, it got neglected for a few months, did a ton of work out in garage, wiring, roofing, cement stuff.... now the bolts are MIA, missing in action. and on the PLUS side, they wouldnt have been long enough anyhow. on the DOWN side, i coulda used em for reference, so at least i'd know what diameter and thread count the females were. now i have NOTHING to go on. my lift is 2 in rear, 2.5 in front. who can tell me what bolts to use? also, the washer/bushing thingys on the mustache bar ball joint are a bit rough lookin, 2 are great, 2 are kinda chewed up. i think they are good enough to use, i guess, but where would i get replacements? Quote Link to comment Share on other sites More sharing options...
tallwelder81 Posted February 24, 2012 Author Share Posted February 24, 2012 bump. i just need to know the bolts for my torsion bar. my rear shocks. my crossmember, and my strut towers. the original factory specs, please!!!???? im sorry if this info is on here somewhere already. i looked some. didnt find anything??? Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted February 24, 2012 Share Posted February 24, 2012 Have you thought of just going to a pick n pull and getting some bolts off another Subaru? that is what i would do. Quote Link to comment Share on other sites More sharing options...
ivans imports Posted February 24, 2012 Share Posted February 24, 2012 the long bolts of the xmembers of a newer legacy are good make shure the end of bolts are marked grade 9 or higher belive they are 11.125 or 12.125 thread pitch Quote Link to comment Share on other sites More sharing options...
tallwelder81 Posted February 24, 2012 Author Share Posted February 24, 2012 but they need to be for a 2 inch lift.... i just want the specs for the ORIGINAL factory bolts because i assumed that info would be more readily available. and i could just go from there. Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted February 24, 2012 Share Posted February 24, 2012 there are many types of lifts. for instance my former 4" lift, used the stock mount bolts for going up into the body mount captive nuts, and used some high grade other bolts for connecting the suspension back to the bottom of the blocks. Some lift kits use stock bolts, some lift kits use long thru bolts instead. Not much more info to say than that. If i had pitch grade, length etc, i would provide it. Quote Link to comment Share on other sites More sharing options...
tallwelder81 Posted February 25, 2012 Author Share Posted February 25, 2012 LIAR!! you have it!! you just wont give it to me!! its a conspiracy!! you probably shot JFK!! lol...... Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted February 25, 2012 Share Posted February 25, 2012 HELP please!! i took apart my guts to swap to a shorter lift kit. but things came up, it got neglected for a few months, did a ton of work out in garage, wiring, roofing, cement stuff.... now the bolts are MIA, missing in action. and on the PLUS side, they wouldnt have been long enough anyhow. on the DOWN side, i coulda used em for reference, so at least i'd know what diameter and thread count the females were. now i have NOTHING to go on. my lift is 2 in rear, 2.5 in front. who can tell me what bolts to use? also, the washer/bushing thingys on the mustache bar ball joint are a bit rough lookin, 2 are great, 2 are kinda chewed up. i think they are good enough to use, i guess, but where would i get replacements? front engine crossmember and strut tops, 10mm x 1.25 thread radius rod/tranny mount 12mm x 1.25 Thread x 30 long rear shock bolts top on body 12mm x 1.25 T x 30 long rear diff 12mm mustache bar to body 10mm x 1.25 x 30 Quote Link to comment Share on other sites More sharing options...
tallwelder81 Posted February 26, 2012 Author Share Posted February 26, 2012 ahhhh ************ man. you are a lifesaver, scott.... i cheaped out and bought my lift used, cuz i didnt want to drive to bellingham... you shouldnt be helping me, man,..,. thanks, you are a helluva guy, scott. Quote Link to comment Share on other sites More sharing options...
tallwelder81 Posted February 26, 2012 Author Share Posted February 26, 2012 lol ok..... im a dope at metric. those have GOTTA be stock measurements, though.... 30mm, thats just a hair past 1 inch, yea? one inch is around 25mm, if i recall?? everything i know about metric conversions, i learned from owning guns and buying ammo, growing up. 12.7 is .50 so 25.4 would be roughly one inch. hmmm,,,,, okay thanks again scott. mucho grassyass Quote Link to comment Share on other sites More sharing options...
tallwelder81 Posted March 7, 2012 Author Share Posted March 7, 2012 how come i used a cuss word that was 4 letters, but when it censored it, there are like a dozen asterisks?> asterixes... however you spell that word. Quote Link to comment Share on other sites More sharing options...
