AdventureSubaru Posted February 21, 2012 Share Posted February 21, 2012 new(ish) 4EAT in a 2000 Outback. Fluids were changed and are new. between gears it seems to lag on occasion (usually on light inclines). RPMS don't really rise, car doesn't accelerate much or want to shift. Once it shifts, it's fine. Doesn't seem to be slipping. Just lazy on the shift. I'm new with automatics. Any thoughts on this? Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 22, 2012 Share Posted February 22, 2012 Does it get better or worse as the fluid warms up? Link to comment Share on other sites More sharing options...
AdventureSubaru Posted February 22, 2012 Author Share Posted February 22, 2012 Can't really say. Seems the same to me. It happens warm or cold. Not sure if a different fluid could help. Right now it's just Wal Mart ATF. Link to comment Share on other sites More sharing options...
TheLoyale Posted February 22, 2012 Share Posted February 22, 2012 Sounds like a kick-down solenoid. Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 22, 2012 Share Posted February 22, 2012 Different fluids can make a difference. The 4eat uses dexron 3 spec fluid, so if the fluid you used does not say it meets that spec you should change it with fluid that does. A bottle of Trans x additive could help improve shift quality if fluid changes didn't help. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted February 22, 2012 Author Share Posted February 22, 2012 Thinking about trans-x anyway. Seems to do good things for Subarus. I used this to correct the delayed forward engagement on the old trans. Pretty sure the fluid I've got meets the standard. I'll double check to be sure. Where would the kick down solenoid be? I have a spare trans so it might be worth swapping to see if that makes a difference. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted February 23, 2012 Author Share Posted February 23, 2012 bump for any further thoughts? trans-x going in this afternoon. We'll see if it helps. Link to comment Share on other sites More sharing options...
coolskaterkid Posted February 24, 2012 Share Posted February 24, 2012 Mine does the same thing. It seems to have gotten worse after a fluid change, mainly more often, not a longer lag, im going to try the dump from the pan one more time, then do the filter, and try the trans x. Let me know if the trans x helps yours Link to comment Share on other sites More sharing options...
