spikemike203 Posted February 22, 2012 Share Posted February 22, 2012 Just installed the weber on my ea82 n it initially started for a second, (probly left over fuel in the intake) and now it will not start at all, any one have good advice Link to comment Share on other sites More sharing options...
oleman77 Posted February 22, 2012 Share Posted February 22, 2012 Are you sure your getting fuel? Did you check your fuel line right at the carb? Link to comment Share on other sites More sharing options...
lilredjusty88 Posted February 22, 2012 Share Posted February 22, 2012 ill put my 2 cents in prolly don't wanna know it but, here goes, your best option is to ditch the carb an convert it to SPFI, i have weber 1bbl on my 83 GL and honestly i don't like it very much, its got hesitation problems starting issues, personally the carbs are becoming more and more scarce for parts. consider the FI upgrade especially if u offroad alot. Link to comment Share on other sites More sharing options...
spikemike203 Posted February 22, 2012 Author Share Posted February 22, 2012 i dnt want to put injection on i switched it from injection to carb because of computer issues, i pored gas down into the carb not even a spudder Link to comment Share on other sites More sharing options...
obk25xt Posted February 22, 2012 Share Posted February 22, 2012 i switched it from injection to carb This... maybe.... Did you switch to the carb fuel pump? If not, do that first. Next, You will also need a disty from a carb car. I don't remember exactly what I did, but you will need the disty too. I ended up with only a very few wires running from the manifold harness to make it run when it was all said and done. Check grounds too, that was a hiccup on my SPFI--->carb swap. Which wasn't worth the effort anyhow. FWIW, you'd have been better off sticking with the SPFI, sorry you gave it up for the carb system. I know this from experience. Link to comment Share on other sites More sharing options...
spikemike203 Posted February 22, 2012 Author Share Posted February 22, 2012 some times its the simple things tht really get me caught up, some how in taking everything off i managed to pop my ignition fuse, i still have all my stuff for injection, maby once i get sick of dealing with the carb ill switch back but for now lil rew is running happy again =) Link to comment Share on other sites More sharing options...
