uwjberg Posted February 22, 2012 Share Posted February 22, 2012 Hi all - I'm looking at getting a SJR 4" lift for a '91 Legacy. I have a couple of questions about it. Any comments or suggestions from experience would be helpful. -Is everything included (any other parts like hardware I would need)? -Do I need any special tools? -How long would it take someone to install it if they had all the tools? -How difficult is it to lengthen the steering shaft? Thanks for the help... Link to comment Share on other sites More sharing options...
eulogious Posted February 22, 2012 Share Posted February 22, 2012 This thread should answer all your questions... http://www.ultimatesubaru.org/forum/showthread.php?t=109402 Austin help with the development on the SJR lift for the EJ, and the thread details almost everything you need to do. I got a 3" SJR lift sitting in my living room just waiting to be installed. Comes with all the bolts/nuts you need, but that's about it. You need to lengthen the steering shaft, and change the bottom radiator hose/fitting, but that's about it. Should be able to do it with all the "normal" tools. Impacts will probably help fight through the rust/grim, but you should be able to do it with "normal" tools fairly easily. Nothing special tool wise I think. Will probably take a full day if you know what you are doing, I would plan on 2 days if you have never done this before. When I do mine, I am planning on it taking 2 days. HTH! Link to comment Share on other sites More sharing options...
