Keyless Entry Mod, Button missing
I happened across a fob at the junk yard that might work with my 98 OWB. I crawled under the dash trying to hunt down the button everyone talks of but did not find it. Only thing that I can figure is there is a two tones wire teminating into one of the plugs but was cut with no other end to match to. :banghead:
Can some one, or has someone have pics of what I would be looking for and maybe the wiring harness for the unit out of the car I can refer to?
Ok, another problem.
When I plug the wiring harness back into the unit it begins to blink repeatedly for a while, then stop for about a min then resumes. I found the button (Very small thing in the middle of all kinds of other things) and pressed it according to instructions and the blinking doesn't change.
Ideas?
Ideas?
You have 98 car, but a 99 system? Did you install it or did it come with the car?
