shortysayhi Posted March 31, 2012 Author Share Posted March 31, 2012 16 to 18ga is perfect for fixing these Subarus, so I've found, 22ga might be a tad too thin, but if its working for you, have at it Its deffinetly thin, but its working so far... might end up just putting another layer of it, on the inside of the wheel wells. Link to comment Share on other sites More sharing options...
shortysayhi Posted April 7, 2012 Author Share Posted April 7, 2012 So i had a question, what other models will work for swapping drivers, and passenger door Glass? Link to comment Share on other sites More sharing options...
TheLoyale Posted April 7, 2012 Share Posted April 7, 2012 I want to say Brat, Hatch and Coupe' are all the same, as they all have the longer style door, not found on Sedans or Wagons. Link to comment Share on other sites More sharing options...
shortysayhi Posted April 8, 2012 Author Share Posted April 8, 2012 Put this on today, it isn't fitting quite right, right now... Link to comment Share on other sites More sharing options...
shortysayhi Posted April 13, 2012 Author Share Posted April 13, 2012 OK, so i need some advice... i am struggling with the idea of using my extra 86 gl D/R trans... with a ej22t. I know the stuff i would need, but i am not sure if its a smart idea, like if theres way to much power and it would tear it apart, or if its possible to use a STI trans (6 speed), if i would need to do some modifications to get it to work? or if i just used a 5 speed manual trans outta a legacy etc... Please i need some adviceeee! Link to comment Share on other sites More sharing options...
TheLoyale Posted April 13, 2012 Share Posted April 13, 2012 The 5spd D/R will hold up just fine, just don't be dumping the clutch and such, its not a race car. The 4spd D/R out of an EA81 could handle the power/torque, but then someone started getting careless and started dumping the clutch and doing burn outs (Blew that gearbox up pretty good) 5spd D/R is the way to go. a STi 6spd will very costly. 5spd Legacy, and then you need to figured out the AWD bs. Link to comment Share on other sites More sharing options...
shortysayhi Posted April 13, 2012 Author Share Posted April 13, 2012 Okay I don't plan on doing burn outs but maybe a little show boating but with the 6 speed would I have to relocate the starter? (my main concern). Or maybe a wrx trans? This project might get pushed out and put on hold (money related) But what would be the ideal set up? And most logical one? Link to comment Share on other sites More sharing options...
TheLoyale Posted April 13, 2012 Share Posted April 13, 2012 I'm not sure about the starter placement on the newer trans, I know on my '95 4EAT is was still in the same spot as an EA82. If you go with an EJ trans, you will need a $200 adaptor plate (or possibly make your own) it has to be the correct thickness as well (1/4" or 3/8" IIRC?) Also, clutch kit is more costly for the EJ trans. WRX might have a Hydro assist, I know the first gen Turbo Legacy does. As for logical, it all depends what you'd like to spend. The 5spd D/R is probably cheaper and you have tabs on one, right? So the hunt is already taken care of. I personally would use the 5spd D/R. Anybody else? Link to comment Share on other sites More sharing options...
shortysayhi Posted April 13, 2012 Author Share Posted April 13, 2012 Yeah, in my parts wagon I have a full trans with matching rear diff. So all id need is the adapter plate. I mean I want to have more of a full time all wheel drive instead of the fw/4wheel. (I'll just deal if I have too..). I do want to keep it pretty simple, but get the best option with cost. Link to comment Share on other sites More sharing options...
TheLoyale Posted April 13, 2012 Share Posted April 13, 2012 Disreguard that part in my last post, I forgot you are going to run an EJ motor, so if you ran an EJ trans you wouldn't need the adaptor plate (Doh) But like you said, you would still need it for the EA trans to the EJ engine. So alls good Link to comment Share on other sites More sharing options...
shortysayhi Posted May 10, 2012 Author Share Posted May 10, 2012 Okay well today i got some motivation to do some work. so i pulled the trans, axle and rear diff. and the exhaust. first off does any one know what gear ratio is the rear diff? (trans is 4 speed if it helps) I don't need this trans or exhaust... so if anyone wants them ill sell em! Link to comment Share on other sites More sharing options...
moosens Posted May 10, 2012 Share Posted May 10, 2012 How much for the Y pipe ? Would you cover the ends and ship it raw? Shipping companies are ok with that. Link to comment Share on other sites More sharing options...
shortysayhi Posted May 11, 2012 Author Share Posted May 11, 2012 How much for the Y pipe ? Would you cover the ends and ship it raw? Shipping companies are ok with that. Make me a offer (PM) and i have no problem shipping anything (i just wanna make sure theres no clogged parts like leafs) So today i contacted someone who had some parts and went down to pick them up! I got: 2 Doors - COMPLETE with mirrors and With perfect glass! 1 Rear glass (double sliding panes) and Gasket 2 front corner lights 1 rear tail light 1 instrument cluster all the bed trim (silver) tailgate handle tomorrow hopefully going back and grabbing rear roll bar (high one) and front mini push bar, and heater core. had to stop getting parts because it started snowing Link to comment Share on other sites More sharing options...
shortysayhi Posted May 11, 2012 Author Share Posted May 11, 2012 (edited) I also have a line up on a 94 EJ22T (obd1?) with 137,xxx on it. for only 900. Would it be better to go with a newer ej22t thats obd2? I also have a hook up on a obd1 (out of a 94) harness with ecu. I honestly don't know the difference between obd1 and 2... could any one elaborate? and could you use a 94 engine with a Obd2? Edited May 12, 2012 by shortysayhi Link to comment Share on other sites More sharing options...
bratman18 Posted May 12, 2012 Share Posted May 12, 2012 94 is OBD1 like you stated, and that was the last year of the EJ22t, so they are all OBD1. Link to comment Share on other sites More sharing options...
shortysayhi Posted May 12, 2012 Author Share Posted May 12, 2012 Okay which means I can't use the obd2 harness. Link to comment Share on other sites More sharing options...
shortysayhi Posted May 12, 2012 Author Share Posted May 12, 2012 (edited) Well got some more parts today. rear xt6 hubs(complete) Brat hi top roll bar Brat front bumper bull bar Dual light front grill Harness Some xt6 hub caps Edited May 13, 2012 by shortysayhi Link to comment Share on other sites More sharing options...
shortysayhi Posted May 15, 2012 Author Share Posted May 15, 2012 Well i got some more stuff! and put some stuff in! front xt6 calipers, and rotors (still have to get the hubs) I got the rear window gasket put in, and temporarily set the roll bar in! it looks Sweeeeeeettt!!!!!!!!! and clears the jump-seat, seat belts and frame. tomorrow swapping the doors and more! Link to comment Share on other sites More sharing options...
shortysayhi Posted May 15, 2012 Author Share Posted May 15, 2012 Got the doors on and glass isn't damaged! Also put a different tail gate on and started to make it fit closed. One tail light is also on, door cards back on, picking up my harness and ecu tomorrow. Got some helpful info about splice/ soldering the harnesses together from Prwa101. Link to comment Share on other sites More sharing options...
shortysayhi Posted May 16, 2012 Author Share Posted May 16, 2012 So dove deep into labeling everything on my brat harness (its super difficult when none of the connections were attached when i bought it. Also starting on my ej harness. I could use some ideas on what trans to get, I'm using a ej trans just not sure whats best legacy, outback legacy, impreza, wrx etc (5 speed is mandatory) Also is running hub adapters really bad for a "street" car? (I'm contemplating them instead of doing a full blown 5 lug swap. (since its so expensive and parts are hard to come by) Link to comment Share on other sites More sharing options...
BratRod Posted May 17, 2012 Share Posted May 17, 2012 Its looking great, and i like your workshop by the way 1 Link to comment Share on other sites More sharing options...
Prwa101 Posted May 17, 2012 Share Posted May 17, 2012 It's lookin good man! Link to comment Share on other sites More sharing options...
shortysayhi Posted May 17, 2012 Author Share Posted May 17, 2012 Its looking great, and i like your workshop by the way Thanks! My dads got all his toys in the garage... so I'm forced out side.. Into the wilderness! It's lookin good man! Thanks! Last night i got this! still trying to locate a ej22t diagram... this looks like its going to be a MAJOR pain Link to comment Share on other sites More sharing options...
Prwa101 Posted May 17, 2012 Share Posted May 17, 2012 hahahah man that brings back the memories!! just wate till the tape is off. then the spider webs begin! Link to comment Share on other sites More sharing options...
shortysayhi Posted May 19, 2012 Author Share Posted May 19, 2012 Alright, i am pretty sure I'm going to get someone else to do the harness for me. I don't trust my self enough! hahaa. But I've also been looking at which would be better, a FRONT mount intercooler or a Top mount? i know theres fab work in both, but is one "better" then the other? Would having a FMIC be bad in the winter because of snow? Link to comment Share on other sites More sharing options...
