so my legacy is letting a HG go.. only reason i say so it my overflow tank is filling up and its got carbon buildup in with it.. and i get air bubbles rushing through the heatercore everyday..
this is a 91' 2.2 legacy with only 104k its never overheated yet, but its going to get pulled before it does so.
i can get a 2.5 shortblock reasonable, just debating on it really.. i already have dual port heads and a tsudo uel header.
will franken motor run ok with stock 2.2 cams? i'm kinda on a budget too, hence the hesitation to jump on it..
nothing wrong with my 2.2 shortblock.
ideas, suggestions, comments?
Yeah the stock cams run fine and if it's a daily driver I would reccomend them. The torque grind cams play havoc with the idle on the OBD-I's.
that was kinda my concern with the project, new cams would stretch the budget...
what would you recommend for clutch? 2.2 or 2.5?
