Quick rear strut question
4wd rear xt struts on a 2wd xt should lower it about 2", likewise rear 2wd xt struts on on a 4wd xt will lift it about 2". Not sure what you can do about the fronts other than shorter springs as the xt front struts are the shortest ea82 struts unless you go with a 5 lug swap and impreza lowering springs and struts. There should be write up on that.
