tizatron Posted February 29, 2012 Share Posted February 29, 2012 Greetings all. My first post. I have a 2000 Legacy Wagon. Looks Like I need a new oil pan. I was wondering if any folks have had luck with the Dorman/Spectra replacement oil pans or is better to get on OEM oil pan. Any thoughts, advice or tips appreciated. -Tiz Link to comment Share on other sites More sharing options...
tizatron Posted February 29, 2012 Author Share Posted February 29, 2012 Here was message about the Spectra Oil Pan I yanked. Was kinda hoping to avoid this experience... Comments about Spectra Premium Oil Pan: You have to lift the engine, re-drill frame or remove cross-member in order to get to rear 2 bolts on Subaru's. The pan itself seems to be solid build "Made in Canada" with a durable high-temp paint coating only on the outside (assuming so paint chips don't end up in oil). Pan does line up to the mounting screws properly but still somehow you end up with the dip stick tube off to side and giving difficulty to reconnect the dipstick to pan. I couldn't get it in quite the way it should been. Drain plug hole size in NON-OEM size so any original quick-drain valves you might have installed can't be reused. You will just have to use drain plug that comes with the pan from this point on. Overall solid build pan made from thick stamped metal sheet. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 29, 2012 Share Posted February 29, 2012 dunno about the parts, but if the pan got dented, be sure to inspect the pickup tube. If it took a hit, it could be bent or cracked. Link to comment Share on other sites More sharing options...
tizatron Posted February 29, 2012 Author Share Posted February 29, 2012 Plan A so far is to try and pull one from a Junk Yard. Called Subaru. They wanted $180 for the part (taxes included). Yikes! That is a lot of sonny bonos. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted February 29, 2012 Share Posted February 29, 2012 Junkyard is your best bet. It's not a part that just wears out. Just be sure you get both mounting surfaces CLEAN before you add your silicone etc. and tighten her up. Link to comment Share on other sites More sharing options...
