rpholz Posted April 27, 2014 Share Posted April 27, 2014 Interested in seeing how you like the manual steering 1 Link to comment Share on other sites More sharing options...
Nico Posted April 27, 2014 Author Share Posted April 27, 2014 (edited) On 4/27/2014 at 2:48 AM, rpholz said: Interested in seeing how you like the manual steering from the reviews on here it seems like the VGR rack is the one to get.... my car is so scary on the hwy as soon as I turn that wheel a inch its like crossing 12 lanes lol... feels like I got a quick rack or something. well people have asked how did I bolt up the coil overs in the rear so easy. in the pictures you can see everything in order. what kit I used is the HSD STi GRB 08-12 set up, what I keep from my Leone is the top mount bracket and spring perch cap. drill the same size hole as the washer from the HSD kit so the spring perch cap will go on. then pop out the bushings & tube from the HSD GR STi stuff and use them on your new set up. the only other thing is the lower mount on a GR STi has a 55mm wide bushing tube, you would need to cut it down to 45mm size to fit in the rear control arm lower. the bolt is the same 12mm size flange bolt so no need for a spacer in the bushing tube. all put together so if one is going to be buliding a Leone in the future the best kit to get would be the Subaru GRB STi 08-12 suspension kit. ohlins ? KW ? Bilstein ? future for me for sure the front you would need the GRB STi 08-12 knuckle with the bolt on bearing which is better they say for its bigger bearing, the top plate will not work unless you drill it out to match your car top mount pattern which is pretty much the same as a 1989-2001 Legacy impreza car pattern. also the rear in the BRZ is the same as the GRB, the front is the same as a 1989-2001 impreza legacy but the shock is shorter but will work also with the non larger knuckles. Edited April 27, 2014 by Nico 3 Link to comment Share on other sites More sharing options...
rpholz Posted April 27, 2014 Share Posted April 27, 2014 Well, my thought is the EA power steering pump sucks. I've looked into swapping to a ej style pump but the bracket is so far off it would take too many hours to make it all work. So if the manual rack works out well in an auto-x or hillclimb situation I'll run that as I have one I pulled from my XT DL. 1 Link to comment Share on other sites More sharing options...
Nico Posted May 14, 2014 Author Share Posted May 14, 2014 On 4/27/2014 at 4:45 PM, rpholz said: Well, my thought is the EA power steering pump sucks. I've looked into swapping to a ej style pump but the bracket is so far off it would take too many hours to make it all work. So if the manual rack works out well in an auto-x or hillclimb situation I'll run that as I have one I pulled from my XT DL. well the manual rack wont fit... I lowered my motor so the sti 6mt would fit and am using the longer u joint any ways when the manual rack is there i would need even a longer u joint... i have a leone wagon im building next so ill use it for that. lots and lots of work went down so far, for the front I changed the rubbing in the pockets of the control arms which alone made the car feel amazing... I stripped everything out and under coated it all along with wrapping my exhaust well worth it all even though its a pain. all the sand blasted powder coated stuff was add along with the upgraded bushings and oem subaru bolts. the only thing missing now is the front GR sti knuckle bearings, the sti sealed bearings are being made into 5x100 from 5x114 thanks to my good friend that owns a machine shop super rare no longer made front bumper clips got made from a 3D printer collage kid which made them so good there better then the real ones.. he used some hard plastic and chemical to harden the clips so they last long. looks amazing now with the second trim on the top of the bumper very happy now. with all the new bushings repaired shocks & fixed cross member, it feels amazing drives like its on rails ! point and shoot now feel ! ... I still need a corner balance & alignment done so it will only get much better. straight from japan !! this is the holy grail of part numbers for my car. with this book and part numbers all I can say is WOW WOW..... there is a boat all read in bound from japan to canada with my new parts on it like the JDM skirt kit, the jdm air dam along with much much more things for this car and my other build the Leone Wagon. 4 Link to comment Share on other sites More sharing options...
138 Posted May 15, 2014 Share Posted May 15, 2014 scan and lay out a general review of n -))) Link to comment Share on other sites More sharing options...
AWD J3wman Posted May 26, 2014 Share Posted May 26, 2014 Still want to get some replacement stickers so I can repaint my wagon...Where did you find those? I feel like I've asked this before on JNC. Link to comment Share on other sites More sharing options...
AWD J3wman Posted May 27, 2014 Share Posted May 27, 2014 On 3/27/2014 at 5:01 PM, bratman18 said: A factory RX front air dam. Thanks Link to comment Share on other sites More sharing options...
nick1208 Posted May 27, 2014 Share Posted May 27, 2014 Could you post some pictures from inside that optional parts book of some parts some of us have maybe never seen? would be cool to see all the JDM options Link to comment Share on other sites More sharing options...
tizzle Posted June 1, 2014 Share Posted June 1, 2014 Link to a vast collection of Subaru catalogues: http://a15ff11300g.sakura.ne.jp/catalogue/AA%20leone/AA-type%20leone.html 1 Link to comment Share on other sites More sharing options...
nick1208 Posted June 1, 2014 Share Posted June 1, 2014 ^ awesome! thanks Link to comment Share on other sites More sharing options...
TripleJ92 Posted June 29, 2014 Share Posted June 29, 2014 This is the most amazing build I have ever seen. Link to comment Share on other sites More sharing options...
Nico Posted August 6, 2014 Author Share Posted August 6, 2014 aeroquip hose fittings and line for the jdm Spec-C oil cooler got my arp studs in the xt6 hubs June 1... and then the virgin Leone meets a guard rail while saving my driving license & insurance hike time to rebuild with all new factory oem parts that are getting hard to find For REAL ! cut the front rad support off not it will be bolt on for that quick release motor swaps lol got around to adding the BRZ koyo rad OEM subaru rad support new test fit and drilling holes for bolt on action jdm Spec-C cooler ready ! Franz welded my AN fittings for me powder coated and bolted up all stainless steel bolts where all the spot welds where with oil cooler everything lines up and my spare bumper beam sand blasted and powder coated also brz filler neck and radiator cap fits nice and some jdm Leone goods, the fogs with power flip the covers on there own lol pretty slick 80s subaru stuff strip down ready for the paint job single stage white BASF Glasurit single stage paint like the factory did $o $hiny and new !.. wow was my factory paint so dull more brand new everything from the dealership oem, shiny paint needs new stickers and symbols home sweet home ready for me to put her back together again all most done jdm 3D corner lights sick jdm SUPER light weight head lights with H4 bulb's jdm lights dont blind on coming traffic these are also used in europe so beam pattern is straight on a wall with no cut lines pretty cool black stuff all back on door moldings mud flaps and lower air spoiler.. lost two moldings for front fender, new ones on the way new oem turbo stickers and jdm Leone tail lights had to add 4WD in my TURBO lol.. started life as FWD now its a real subaru all updated and still got small things to add again, trim parts around the windows and front bumper cover. 3 Link to comment Share on other sites More sharing options...
KootenayJK Posted August 6, 2014 Share Posted August 6, 2014 Sexxxy! 1 Link to comment Share on other sites More sharing options...
KiwiGL Posted August 6, 2014 Share Posted August 6, 2014 Do you mind if I ask how you pranged it? Glad it wasn't any worse and that you're okay! Link to comment Share on other sites More sharing options...
nick1208 Posted August 6, 2014 Share Posted August 6, 2014 (edited) Car looks good as ever. think you could get us a video of you driving it? getting on it a bit? Edited August 6, 2014 by nick1208 Link to comment Share on other sites More sharing options...
AWD J3wman Posted August 13, 2014 Share Posted August 13, 2014 Out of curiousity, did anything need to be modified to fit the BRZ radiator into the Leone radiator support? Link to comment Share on other sites More sharing options...
Nico Posted August 14, 2014 Author Share Posted August 14, 2014 (edited) On 8/6/2014 at 7:32 AM, KiwiGL said: Do you mind if I ask how you pranged it? Glad it wasn't any worse and that you're okay! I tried stopping, skidding in the back of a car was not a option for me tried to squeez on the left of it between guard rail and stopped traffic.. There was a groved section that sucked me in and pulled me right two it.. Didn't hit the car but messed up my toy, made it home safe banged up. On 8/6/2014 at 8:23 PM, nick1208 said: Car looks good as ever. think you could get us a video of you driving it? getting on it a bit? Hitting the track up soon can't wait to test out all new goods, I'll post it soon On 8/13/2014 at 4:01 PM, AWD J3wman said: Out of curiousity, did anything need to be modified to fit the BRZ radiator into the Leone radiator support?[/size]Rubber stoppers on the bottom of our rad fit on brz rad.. Then copy same hole diameter as factory size.. Drill 2 new holes where the brz has it's post/pegs at... Also you will need to cut some tabs off the brz rad and shave them down.. It's a tight fit but works.. Make sure you test fit because inbetween the head lights you got to centre perfect or else you won't make it in the flushist spot.. On 5/26/2014 at 8:57 PM, AWD J3wman said: Still want to get some replacement stickers so I can repaint my wagon... Where did you find those? I feel like I've asked this before on JNC. Subaru has them still.. Got them new. 4WD TURBO is still can be bought new. Edited August 14, 2014 by Nico Link to comment Share on other sites More sharing options...
Nico Posted August 28, 2014 Author Share Posted August 28, 2014 car is back up and running, oil cooler and brz rad are working very well with the new set up. its time to get it out on the track before winter comes. 3 Link to comment Share on other sites More sharing options...
nick1208 Posted August 28, 2014 Share Posted August 28, 2014 Sweet pics! I'm still dying for another video of this thing driving and accelerating. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 29, 2014 Share Posted August 29, 2014 Appreciated Nico, While it was really Sad to see your Awesome Subie with that hit, it is really Awesome to see how you managed to use the situation to improve your Subie even more... which seemed impossible. By the way, I mentioned long time ago, in another thread, the H4 Headlamps with Plastic housing / front Glass, which was widely used in the LADM (Latin American Domestic Market) Specs subies, starting in year 1990. I only know about another USMB Member who obtained similar ones from Germany. Also, the Yellow Halogens with Self moving Covers are Really Awesome!!! ... ... and it is something really New for me, which explains the rare Switch I Found long time ago in an Early EA82 Turbo at a Local Junk Yard, this one: . . I Bet it is the one which activates those covers, because it features identical symbol than the Older Subarus with the "Third Eye" in the middle grille; I mean this Switches: . . Would you like to share photos and info of those Subaru Halogens with Automatic Covers, on the thread about Rare optional parts on Subarus? Thank you for sharing those beautiful photos and the repairs of your fantastic subie. Kind Regards. Underlined words are web links ☺ 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 13, 2014 Share Posted September 13, 2014 On 8/29/2014 at 1:00 AM, Loyale 2.7 Turbo said: ... Would you like to share photos and info of those Subaru Halogens with Automatic Covers, on the thread about Rare optional parts on Subarus? ... What I did, is to Save the Photos, and re-Host them onto my Albums, in order to Avoid Stealing your Bandwidth, and I re-posted them on that Thread, writing that they belongs to you of course. I only wanted to share Real Life Examples of such Rare parts. I hope you don't mind that. Kind Regards. 1 Link to comment Share on other sites More sharing options...
two85s Posted September 20, 2014 Share Posted September 20, 2014 On 6/29/2014 at 6:02 PM, TripleJ92 said: This is the most amazing build I have ever seen. Pure Automotive Wizardry......please keep posting. Inspirational Build. Thanks for sharing, Aaron Link to comment Share on other sites More sharing options...
Nico Posted February 17, 2015 Author Share Posted February 17, 2015 On 9/20/2014 at 11:22 PM, two85s said: Pure Automotive Wizardry......please keep posting. Inspirational Build. Thanks for sharing, Aaronthank you, still got lots to do so its not over yet so decided to improve the handling of the car a bit better and I noticed the 2015 uses rear spherical bearings. I had a machine shop shave them down each side 1.5mm and made a spacer to take up the slack for pressing them in my lower suspension mount in the rear of my coil overs locally I found a nice set of ES-Tarmac ENKEI wheels 5x100 16x8 et45 14lbs wheels, super light weight compared to my braid wheels started to build the spare motor, Ej22T stock crank, 10mm oil pump, ACL bearings, Carrillo Rods, Wiseco pistons, cometic head gaskets, ARP Custom Age 625+, V9 STi heads, killer b pick up, and allot of new factory case bolts and plugs gaskets 2 Link to comment Share on other sites More sharing options...
two85s Posted February 17, 2015 Share Posted February 17, 2015 Hey...I got an idea. I'll let you experiment, "practice", and such on my 1985 GL wagon. ....Cheers, you do amazing work!! 1 Link to comment Share on other sites More sharing options...
Nico Posted February 19, 2015 Author Share Posted February 19, 2015 On 2/17/2015 at 4:16 AM, two85s said: Hey...I got an idea. I'll let you experiment, "practice", and such on my 1985 GL wagon. ....Cheers, you do amazing work!!lol bring it on over so this is what else I'm working on at the moment along with the lower pillow ball bushing for my coil overs, I decided to get a one piece unit made so I can get rid of the rubber spacers and all that mess.. this is a prototype unit to test on the car then i can get them made up once it fits ok. black is 80s strut mount, green is coil over mount.. needs a bit more work to be perfect fit also found the rear garnish in japan for my car, maybe ill put it on. to many holes to drill in a clean car. 3 Link to comment Share on other sites More sharing options...
