sasquatch86 Posted March 3, 2012 Share Posted March 3, 2012 I have read so many different reviews on which clutches to use my head is spinning. I have an '83 GL wagon '86 GL 5speed d/r trans '90 EJ22 4" SJR lift 27" grenral grabbers on 14" pugs I got the adapter plate and the flywheel from SJR too. Should I go with the XT6 clutch kit and pressure plate? I'd like to hear opinions on this. I want to drop the motor in next week. Thank! Link to comment Share on other sites More sharing options...
obk25xt Posted March 3, 2012 Share Posted March 3, 2012 Should I go with the XT6 clutch kit and pressure plate? Yep, you got it! That's the one.... Link to comment Share on other sites More sharing options...
sasquatch86 Posted March 3, 2012 Author Share Posted March 3, 2012 That's what I was leaning towards. I have found a bunch but they all vary in price so much. Any suggestions where I should buy it? Link to comment Share on other sites More sharing options...
Crazyeights Posted March 4, 2012 Share Posted March 4, 2012 I just got done with a similar swap and a Sachs XT6 clutch kit feels great in mine. Some have said however that the only way to get a pressure plate with the full XT6 clamping force is to buy it from the dealer. I guess it comes down to how much you want to spend and how hard on it you intend to be. Just make sure the flywheel stepping correctly matches the pressure plate you choose. Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 4, 2012 Share Posted March 4, 2012 So you're using a re-drilled EA flywheel with an XT6 clutch? Does the XT6 clutch have the 8-7/8" disc with 24 spline? Link to comment Share on other sites More sharing options...
Crazyeights Posted March 4, 2012 Share Posted March 4, 2012 I am using an XT6 flywheel drilled by SJR and machined by a local shop. It is mated to a '93 EJ22 with Scotts adapter kit and a Sachs XT6 clutch kit, yes 8 7/8 x 24 spline. Trans is a (modified) 3.9 ratio RX box with center-locking diff and 23 spline stubs for EA81 front axles. Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 4, 2012 Share Posted March 4, 2012 Is the XT6 flywheel any different than an EA? I can get an EA flywheel easy, but if it means I would have to use the smaller 7-7/8" disc I'll hold out for an XT6. Also, got a part number for that Sachs kit? Link to comment Share on other sites More sharing options...
Crazyeights Posted March 4, 2012 Share Posted March 4, 2012 The 8 7/8 EA82 flywheel will work and is more commonly used I think. The only difference is weight about 27 lbs for the EA82 and 24 lbs for the XT6 one. I don't think you can use an EA81 flywheel for an EJ swap at all, but I could be wrong. Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 4, 2012 Share Posted March 4, 2012 That makes it much easier then. Thanks for the info! Link to comment Share on other sites More sharing options...
Numbchux Posted March 4, 2012 Share Posted March 4, 2012 XT6 flywheels have a slightly different step, and are lighter. But XT6 and EA82 clutch kits will interchange. I've used a Beck/Arnley XT6 clutch kit from RockAuto 3 times. Once in an Xt6, and twice in Ej swaps. I absolutely love 'em, very high quality (all new parts, not remanufactured), doesn't slip, but very forgiving.. I will be using one in my Brat once I get the EJ swap done in it. Link to comment Share on other sites More sharing options...
Gloyale Posted March 4, 2012 Share Posted March 4, 2012 I don't think you can use an EA81 flywheel for an EJ swap at all, but I could be wrong. Sure you can, if you are putting it with a 4spd it's no different. It can be used with the 5spd too (at least the larger 225mm ones) but it's thicker so some have had to space out the starter. No totally sure. Link to comment Share on other sites More sharing options...
