spikemike203 Posted March 5, 2012 Share Posted March 5, 2012 I finally got the oppertunity to go out and try my latest mods on my 87 ea82 gl, new weber carb and snorkel adapt. i just put a crappy pepboys cone filter on there for the test. wen going threw sugar sand (floridas finest) it would bog down and go the a crawl if i didnt keep it above 2200 rpm, if i floor it to long up to 4500 rpm it will spuder SOMETIMES, never in first just in 2-5 i had to keep my car in a 2300-4500rpm rang witch kind sucks cuz one the road its quick i can feel the power (what little it has), no problems, under stress i think it gets too much gas? my choke is not hooked up is tht a rason? (the snorkle stops were a fuel injected airbox would be) Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 5, 2012 Share Posted March 5, 2012 Hooking up the choke would be wise. You can't tune or adjust it with the choke not pulled off. GD Link to comment Share on other sites More sharing options...
spikemike203 Posted March 5, 2012 Author Share Posted March 5, 2012 i just thought the choke helped restrict airflow when the car is starting cause its cold, its like 80+ here Link to comment Share on other sites More sharing options...
TeamCF Posted March 5, 2012 Share Posted March 5, 2012 Not having the power wire going to the choke will pretty much keep it always choked. The electric Weber choke works by heating up and then staying hot. This gradually opens it as the engine warms up. Granted it's all a bit more complex than that as there are linkages involved as well. (Which should be opening it as the throttle opens) But that gives you the idea. I'm not 100% on how the EA82 is. But on my EA81 the Hitachi had an electric choke. I just made a wire that plugged into the proper terminal on the plug that went to the stock carb and ran it to the Weber choke (now that I got it going and know it passes emissions I'll proly cannibalize the plug that was on the stock carb to make it look neater). Link to comment Share on other sites More sharing options...
spikemike203 Posted March 11, 2012 Author Share Posted March 11, 2012 Hooked up choke made sure it had power and the same thing happens, under stress it bogs down and stays bogged until I lift my foot up off the peddle then it goes, Link to comment Share on other sites More sharing options...
desertsubaru Posted March 11, 2012 Share Posted March 11, 2012 Are the jets correct. Float level being off will cause that to. Link to comment Share on other sites More sharing options...
nickeggen32 Posted March 12, 2012 Share Posted March 12, 2012 Did you install a fuel regulator when you did the swap? Sometimes the sputtering at high rpms is because the fuel pump is putting out more fuel than the weber likes. I had the same problem, but a fuel regulator helped a lot. Link to comment Share on other sites More sharing options...
spazomatic Posted March 12, 2012 Share Posted March 12, 2012 Are you maybe stickin your foot to the floor, too early? with the weber having a mechanical secondary, the carb wants to opened gradually, and proportionally to what kind of RPMs your running. my rule of thumb is, if your between 2-3000 RPMs, the throttle should be open 2/3 of the way. between 3-4000, open it 3/4 of the way. 4-5000 = floor it. I could be wrong, but I get good power (hahaha!) driveability and mileage out of it that way. Link to comment Share on other sites More sharing options...
spikemike203 Posted March 13, 2012 Author Share Posted March 13, 2012 nickeggen32 said: Did you install a fuel regulator when you did the swap? Sometimes the sputtering at high rpms is because the fuel pump is putting out more fuel than the weber likes. I had the same problem, but a fuel regulator helped a lot. This is Probly true I forgot to mention I have a universale 4-6 cylinder fuel pump, it's Probly flooding the motor, what kind of regulator did you get? Link to comment Share on other sites More sharing options...
kanurys Posted March 13, 2012 Share Posted March 13, 2012 Cheap regulators suck. Correct me if I'm wrong, but you want to get one that can adjust down to around 3 to 4 psi accurately. It kind of sounds like it's running rich. Check your plugs to be sure, then clean them up before retuning. I agree about driving the carb in stages, but if its properly tuned, you should be able to put your foot in it above 2000 rpm without it crashing. What main jets and air correctors are you running? What's your altitude? Link to comment Share on other sites More sharing options...
spikemike203 Posted March 13, 2012 Author Share Posted March 13, 2012 i do not kno what jets they are i just got the kit from redline for the ea82 and threw it on there im in florida so idk 20 feet above sea level lol Link to comment Share on other sites More sharing options...
