bulldog Posted March 6, 2012 Share Posted March 6, 2012 I need to know where to get an adapter plate. I live in washington state. I would like to know what else is needed to put this trans with this engine. Quote Link to comment Share on other sites More sharing options...
tractor pole Posted March 6, 2012 Share Posted March 6, 2012 you also need a re-drilled EA82 flywheel or flexplate. SJR lifts does both flywheels and adapter plates, there are a few others that do them too. Although you can do the flywheel yourself fairly easily. Ben Quote Link to comment Share on other sites More sharing options...
bulldog Posted March 7, 2012 Author Share Posted March 7, 2012 (edited) will the ea82 flywheel have an effect on the starter positioning and will the adapter plate move the trans back enough to affect the driveline. Edited March 7, 2012 by bulldog Quote Link to comment Share on other sites More sharing options...
bulldog Posted March 7, 2012 Author Share Posted March 7, 2012 will the ea82 fly wheel have an effect on the starter positioning and will the adapter plate move the trans back enough to affect the driveline. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted March 7, 2012 Share Posted March 7, 2012 will the ea82 fly wheel have an effect on the starter positioning and will the adapter plate move the trans back enough to affect the driveline. No issues with starter or trans positioning. The EJ bellhousing is 1/2" shorter than the EA82, so when you add the adapter thickness, you end up back at the OE EA82 dimensions. Quote Link to comment Share on other sites More sharing options...
ivans imports Posted March 7, 2012 Share Posted March 7, 2012 my freind regan in kelowna bc makes them and i uhsaly bolt the ej flywheel to the ea flywheel drill out the bolt holes rotate the holes and drill the other two holes just did one 91 turbo legacy engine in a 88 gl wagon high low wrked well do not use ej flywheel unless willing to modify starter mount Quote Link to comment Share on other sites More sharing options...
bulldog Posted March 8, 2012 Author Share Posted March 8, 2012 Thanks for the information. The car is a 91 Legacy wagon with a 4inche SJR lift kit and outback struts and 28 inch allterane tires but needs the 4 high & low to make it more complet for off roading . so thanks again for the information im sure i will be asking for more help as i get more into this car I also have a 85 gl wagon that i would like to put a 6inch lift under some time in the near furture. Quote Link to comment Share on other sites More sharing options...
