cal_look_zero Posted March 7, 2012 Share Posted March 7, 2012 Ok, need a quick and dry answer. Found a set of heads on CL that I want to buy so I can build a longblock instead of having to use my stock heads and being down for a few days. Problem is, the heads are all over the place as far as configuation. Here's the configuration: EJ22 Single Port Bodies Solid Lash Adjusters Flat Tappet Rockers Cams unknown. I thought there was no such thing as an SLA/flat tappet configuration, and especially that all single port heads were roller rockers. I'd hate to buy these if they're damaged as a result of micx n matching incompatible parts. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 7, 2012 Share Posted March 7, 2012 Is there pictures? I would say they just don't know what they are looking at. I've never seen flat rockers and solid lifters. I would go as far as to say they don't exist because I've seen enough of these to know that SLA only came two years after roller rockers were introduced. GD Quote Link to comment Share on other sites More sharing options...
cal_look_zero Posted March 7, 2012 Author Share Posted March 7, 2012 Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 7, 2012 Share Posted March 7, 2012 No clue then. I guess they could have come from an import engine or something. I've seen the inside of every single year of EJ22 on the USDM stuff and I've never seen that config before. Maybe some strange year of the EJ18? I haven't messed with many of those but I'm told they are virtually indistiguishable from a casting and valve perspective. So much so that head shops can't even tell them apart without marking them. Though the combustion chamber sizes may be slightly different. GD Quote Link to comment Share on other sites More sharing options...
cal_look_zero Posted March 7, 2012 Author Share Posted March 7, 2012 Supposedly, they came off a 93 engine. I thought the 18 only came with a dual port casting though? Quote Link to comment Share on other sites More sharing options...
CoupedUpSubie Posted March 7, 2012 Share Posted March 7, 2012 I don't see anything that doesn't say they are definitely not roller rockers. I see the SLA and the top of the "tappet" or valve and that it. I don't see how the cam hits the rocker arm so there is no way to really say. Quote Link to comment Share on other sites More sharing options...
cal_look_zero Posted March 7, 2012 Author Share Posted March 7, 2012 I don't see anything that doesn't say they are definitely not roller rockers. I see the SLA and the top of the "tappet" or valve and that it. I don't see how the cam hits the rocker arm so there is no way to really say. The rollers are easily visible on the exhaust rockers. Quote Link to comment Share on other sites More sharing options...
CoupedUpSubie Posted March 7, 2012 Share Posted March 7, 2012 Thanks, couldn't find a picture myself. Quote Link to comment Share on other sites More sharing options...
cal_look_zero Posted March 7, 2012 Author Share Posted March 7, 2012 This is a hydro/flat assembly. Maybe I need a better lit picture from him. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 7, 2012 Share Posted March 7, 2012 They really look like roller rockers to me. I think the lighting is just so out of whack we can't see the whole roller on those exhaust rockers. They're from an engine that was IN a 93? Possible the heads and/or engine were swapped at some point in the past. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted March 7, 2012 Share Posted March 7, 2012 Flat Tappet Rockerssorry but i have to ask, what are these and how are they different from my 95 - 96 engines? i know about the SLAs vs HLAs. is this the part of the rocker that rides on the cam? thanks. Quote Link to comment Share on other sites More sharing options...
ivans imports Posted March 7, 2012 Share Posted March 7, 2012 have seen a few different configureations of heads now what i can tell you [ do not mixup cams roller cam to roller cam non roler to non roller cam dont run so good if you get it switched i put the newer roller cam train on to the 2.2 turbo heads to get the better valves with roller train first time we just changed the valvetrian and not the cam dident run so happy but did run Quote Link to comment Share on other sites More sharing options...
