peugeot wheel center bore
Not sure what you are referring to by 'CBL ring' (centreing ring?) but Subies of this vintage are not hub centric - the wheels are located with the wheel nuts (they should be torqued correctly) and I assume the Peugeot rims are the same.
Sorry man, see the 4 ribs between the disc bolts, they are what centers the wheel, without them you get hardcore vibrations. I just want to find out about the peugeot sizing as Im guessing they are different surely...
column%20trims%20-%20USDM_zpsfg7xl4fl.jp
Edited by nncoolg
And yet the rear brake drums do not have those little lugs (at least from my poor memory...). Despite those lugs Subarus from this area are not hub centric.
Yes there is difference in the centre bore size, the Peugeot bore is slightly larger but not by much, say 5mm (really rough measurements at night, in the dark, from the front of the wheel - Subaru 80mm, Peugeot 85mm).
