1-3-2-4 Posted March 8, 2012 Share Posted March 8, 2012 As I was going around a corner I saw my lug fly off to the left so I pulled over when I got out of the corner and I see how it snapped still a bit of thread left but it's still gone. From what I hear you can't remove the stud before the ABS tone ring is in the way? As far as removing it does heat work? Quote Link to comment Share on other sites More sharing options...
CoupedUpSubie Posted March 8, 2012 Share Posted March 8, 2012 I am not sure about the ABS tone ring problem(as I do not have ABS) but a good 16 oz ball peen hammer drives them right out. Quote Link to comment Share on other sites More sharing options...
bstone Posted March 8, 2012 Share Posted March 8, 2012 This sort of thing happens. Just gotta bang it out and put in a new stub. It's a lot of fun. Quote Link to comment Share on other sites More sharing options...
ocei77 Posted March 8, 2012 Share Posted March 8, 2012 The ring is held on with allen screws either 5 or 8mm, not sure which. Remove and let the ring hang down before you bang the stud out. Lessens the chance of the stud flying and breaking the tone ring. (ask me how I know!) O. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 8, 2012 Author Share Posted March 8, 2012 So it's ok to bang the stud out? I keep hearing other people saying it's not ok and some say its ok but don't go crazy. I figure heat and some kroil should be enough if it ever happened to be stuck. Quote Link to comment Share on other sites More sharing options...
CoupedUpSubie Posted March 8, 2012 Share Posted March 8, 2012 There is no other way to get it out. I guess you could have it pressed out but that is 10x the work. I removed the caliper and positioned the stud so it would pop out the backside and drove the new one in. To make sure it is completely seated flip your lug nut over so the flat surface hits the rotor and tighten until its out as far as the rest. Double check after 50 miles or so. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 8, 2012 Author Share Posted March 8, 2012 Yeah I figured that much I gotta make a note to stop at the dealer to pick one up. Quote Link to comment Share on other sites More sharing options...
ronemus Posted March 9, 2012 Share Posted March 9, 2012 Banging on the stud is a good way to damage the wheel bearing. I removed mine with a gear puller after drilling a shallow hole in the end of the stud to locate the puller. To install the new one I just mounted the wheel and used the lug nut to pull it in - no impact, much kinder to the bearing. Quote Link to comment Share on other sites More sharing options...
987687 Posted March 9, 2012 Share Posted March 9, 2012 I wouldn't hammer on a wheel stuf. For the same reason I won't use a slide hammer installing axles. It will ruin the wheel bearings. I use a propeller puller to get the studs out. If you break the ABS tone ring (which I did replacing brakes once, long story...) you can cut a new one in half very carefully then install it. It works. You don't have to take the bearing apart, makes life happy. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 9, 2012 Author Share Posted March 9, 2012 (edited) I'm just going to get that tool that braces behind the hub and has the bolt that pushes on the stud I forgot the name of the tool but yeah I'm going to do that. *edit wait can't I use a C-clamp? Edited March 9, 2012 by 1-3-2-4 Quote Link to comment Share on other sites More sharing options...
CNY_Dave Posted March 9, 2012 Share Posted March 9, 2012 I'm just going to get that tool that braces behind the hub and has the bolt that pushes on the stud I forgot the name of the tool but yeah I'm going to do that. *edit wait can't I use a C-clamp? If it'll take the force... but it sometimes takes a lot of force. You could borrow a ball-joint or other press from autozone/advance/pep boys. Quote Link to comment Share on other sites More sharing options...
Ricearu Posted March 10, 2012 Share Posted March 10, 2012 just put a large socket over the back side of the stud and clamp straight on the stud from the front. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 11, 2012 Author Share Posted March 11, 2012 Hmm did not think of it like that I think my C clamp is 10 inches Quote Link to comment Share on other sites More sharing options...
