ea dash removal for ej swap
I pull the dash.
I route my wiring through the large grommet in the passenger side of the cowl, where the AC wiring goes. (if you are ditching A/C you can cut out the whole A/C pigtail)
I carefully slice open the big rubber plug, and route my EJ wiring through it.
I mount the ECU behind the glovebox (EA82) or under it above the shelf (EA81)
My personal preference.
I completely removed the harness that went to the engine bay and removed all the EA engine related stuff. Then I spliced the EJ engine wiring together with the EA leftover wiring (lights, horns, etc) and put it all back in just like it was factory.
My ECU is in the same location as OEM.
Doing this way, and getting it done reasonably quick with no mistakes, is an accomplishment, even for a soob expert. You cars are a study in subaru retrofiting.
But for a relative newbie might not be so easy.
That's why I recommend piggybacking the whole EJ hanrness as a standalone. Leave the EA wiring alone other than the few attachments of EJ leads. Makes troubleshooting easier. And leaves you a path out if completely screw up and you want to go back to stock.
I always piggy-back them. Merging the harness is not neccesary and IMO is more work than it's worth. Plus you retain the ability for the car to run a stock engine if you ever want to pull your swap and put it in another chassis.
Merging is the SOP on EJ to EJ swaps. But is of little value on EJ to EA swaps IMO. Especially the older you go - carbed cars have very little wiring to control the engine anyway so stripping it out doesn't really buy you much. More useful in FI cars but again - a lot more work for a tiny gain in appearance. And none of my piggy-back swaps look messy or disorganized in any way. Just a few unused connectors zip-tied out of the way.
