SubeeTed Posted March 15, 2012 Share Posted March 15, 2012 Hi ALL! I opened the PAss door yesterday, heard this load snap, said a few things out load, then looked around inside of my door. That thing that slides in-and-out as you open the door snapped were its bolted to the body of the car. Now the slide thing doesn't slide anymore! I don't know if it failed to slide, then when I opened the door it broke it off, or what ! So the question IS.....can it be easily fixed without taking the door apart ? I can see there are a few bolts that can be gotten to on the outside (of the insdie of the door ) of the door. I have a 2001 Legacy GT Wgn. Just what is that part called ??? Many thanks, SubeeTed Link to comment Share on other sites More sharing options...
Mike104 Posted March 15, 2012 Share Posted March 15, 2012 Looks like its called Checker assembly-front door, 62302FC002 (Item 11) http://opposedforces.com/parts/legacy/us_b12/type_30/body_equipment_exterior/front_door_panel_and_rear_slide_door_panel/illustration_1/ Looks like it requires entry into the door to replace the assembly Link to comment Share on other sites More sharing options...
