Steveman09 Posted March 23, 2004 Share Posted March 23, 2004 Hey guys, ever since I got my GL-10 it has had a funky idle. Here's what happens : When COLD, if I start it up the engine shakes for about 5 seconds then streightens right up and idles around 1500-2000rpm until warmed up where it idles at 900-1000rpm on a WARM restart the idle will stay very low for about 15 seconds then slowly go up to its normal 900-1000rpm. It annoyes the hell out of me. What do you guys think it could be? The WARM restart bothers me the most. Link to comment Share on other sites More sharing options...
NoahDL88 Posted March 23, 2004 Share Posted March 23, 2004 when its cold, its running in cold enrichment mode to keep it running, it'll do that, if it does it too long the temp sender for the computer may be bad. as far as the warm restart, it could be the same thing, if the computer reads that its warm it won't cold idle enrich, but it then finds out that it needs to enrich more that it thought to keep the engine running. on a random tangent when's the last time you've replaced your fuel filter, that could cause some issues with the fuel system, its always the best place to start. Link to comment Share on other sites More sharing options...
Steveman09 Posted March 23, 2004 Author Share Posted March 23, 2004 Here's a list of thing's ive done within the last 1000miles : NGK Spark Plugs (gapped .040) Cap & Rotor Genuine Subaru Fuel Filter Fuel Injection Cleaning 180F Lower Temp Thermistat Link to comment Share on other sites More sharing options...
NoahDL88 Posted March 23, 2004 Share Posted March 23, 2004 make sure that your wires are all on good and tight Link to comment Share on other sites More sharing options...
Steveman09 Posted March 24, 2004 Author Share Posted March 24, 2004 I think I may have fixed it, at work with it up on the rack I noticed a vacuum line that was near falling off so I pushed it back in good and snug and the idle problem has gone away! I'll see tomarrow morning when its cold. Link to comment Share on other sites More sharing options...
Partsman Posted March 24, 2004 Share Posted March 24, 2004 How come the colder t-stat? Could cause you to not reach closed loop on the computer and have it stay running enriched (probably only on cold days). Link to comment Share on other sites More sharing options...
Steveman09 Posted March 24, 2004 Author Share Posted March 24, 2004 The cooler Thermistat helps resist detonation (turbo only) and keeps the engine cooler on hot days. Havent had any problems on 40F day's, milage has actually increased a bit. Plus going from 190 to 180 wont shock the ECU like going from a 190 to a 160 (if you can find one) Link to comment Share on other sites More sharing options...
