blinkytoo Posted March 20, 2012 Share Posted March 20, 2012 I need to replace my rear struts/shocks on my 2000 Outback. I see reviews on Amazon for the Monroe that say they suck. Other people say KYB is too stiff. Any thoughts?? Link to comment Share on other sites More sharing options...
987687 Posted March 20, 2012 Share Posted March 20, 2012 Personally, I'd go with the kyb GR2 struts. I've recommended them to a few friends, and installed them. They work quite nicely, maybe a tad stiffer than stock. But they ride very nicely. Link to comment Share on other sites More sharing options...
bheinen74 Posted March 20, 2012 Share Posted March 20, 2012 KYB=OEM. KYB is the manufacturer of the original shocks on your car. Monroe is junk. Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 20, 2012 Share Posted March 20, 2012 I'll third or fourth or fifth or whatever number that Monroes suck. Don't even waste your time. You're better off with worn out leaking factory struts with 275k miles on them. KYB makes the stock parts. Brand new struts from Subaru even have KYB stamped in the case. Their replacements are equivalent to how the car would have rode when new. Otherwise there is Gabriel, they make quality parts. I don't know if I've ever read of anyone using them on a Subaru. A friend of mine needed shocks for his Volvo 240 wagon several years ago. Put a set of Monroes on it and they made the car nearly undriveable. A set of Gabriels made it ride like it was new, and they are still on the car now about 90k miles later. Link to comment Share on other sites More sharing options...
Ionlyhave3suubs Posted March 20, 2012 Share Posted March 20, 2012 Even though the KYB is generally considered a brand for imports, I even put a set on my '68 Camaro. Love em. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 20, 2012 Share Posted March 20, 2012 If yours are worn out, expect ANY new struts to feel tight/stiff. I just put KYB on my wife's outback last fall, no regrets. You might consider new strut mounts too. Inspect the boots, I just moved mine over, but if they are torn you may need to order some. Link to comment Share on other sites More sharing options...
afterbang Posted March 20, 2012 Share Posted March 20, 2012 Today, installation of 4 new GR-2s on my 98 outback was completed. my old struts were stamped KYB and Subaru so yes, they are OEM. I put regular Legacy struts instead of Outback struts and they feel awesome. I think any new strut will feel stiff when your old ones are on the way out. If you replace the strut mounts, go with OEM ones. They are as much or cheaper than KYB ones. One of the KYB mounts I received was defective too and had to be replaced. Link to comment Share on other sites More sharing options...
john40iowa Posted March 20, 2012 Share Posted March 20, 2012 No comparison in my opinion. I have had both on American and my Forester. The KYB come much closer to OEM and last longer. This at least, with my 500K plus years on the road. Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 20, 2012 Share Posted March 20, 2012 john40iowa said: No comparison in my opinion. I have had both on American and my Forester. The KYB come much closer to OEM and last longer. This at least, with my 500K plus years on the road. What were the dinosaurs like? :-p Link to comment Share on other sites More sharing options...
john40iowa Posted March 20, 2012 Share Posted March 20, 2012 Link to comment Share on other sites More sharing options...
Rooster2 Posted March 20, 2012 Share Posted March 20, 2012 Monroe earned the reputation thirty years ago of building a shock that was good for only about 20K miles on American cars. I have put KYBs on my past Audis and VWs, and was happy with the ride and longevity of the KYBs. My vote is for KYBs. I just don't know if Monroe has improved their product. Link to comment Share on other sites More sharing options...
subaruplatt Posted March 20, 2012 Share Posted March 20, 2012 (edited) I am ready to put in the saab struts into my 06 impreza, they are a direct fit and have KONI inserts! Anyway because people have commented on shocks I would say that KONI and Biltstien have shared the number 1 spot forever, especially their stainless models. FYI I have read that the Tokico HP series are the next higher in regard to the KYBs. I put in my gulf a brand called boge turbo gas and they were a lower midlevel price but much cheaper than bilstien. Anyhow because they were nitrogen pressurized it meant that the were really good. Any kind of "Nitrogen" upgrade will be vastly better than non Nitrogen stock. Edited March 20, 2012 by subaruplatt Link to comment Share on other sites More sharing options...
kanurys Posted March 22, 2012 Share Posted March 22, 2012 Aren't GR-2's a gas pressurized shock? Link to comment Share on other sites More sharing options...
WoodsWagon Posted March 22, 2012 Share Posted March 22, 2012 I've had bad luck with rear KYB-Gr2's on legacys. They seem to blow out within a year on the admittedly bad roads around here. The fronts seem to hold up fine. Link to comment Share on other sites More sharing options...
subaruplatt Posted March 22, 2012 Share Posted March 22, 2012 kanurys said: Aren't GR-2's a gas pressurized shock? Your right the Stock 2000 outback shocks were likely already gas pressurized shocks. Link to comment Share on other sites More sharing options...
davebugs Posted March 22, 2012 Share Posted March 22, 2012 I have run a lot of KYB's on mostly the old air cooled VWs. I have had Monroe's on my 01 VW Golf for the last 140k and they are still in excellent shape. I did Monroe's because at the time believe it or not Sears was runing a deal in Feb I beleive where they installed them all and aligned it for a little cheaper than I could buy the parts. ABout the only work I've ever had anyone else do on that car. I have installed Monroe socks/struts on Subaru's since that's what my local independent parts place stocks with no issues. But then again I sold those cars so I can't report on how well they lasted. I think Monroe gets a bad rap a lot of the time. KYB's have been too stiff for some applications where I have used them. Bilsteins, Koni's, etc I think are a bit of a waste of money. This from someone who used to drive 50k per year and owns a dozen vehicles. FYI I think Gabriel's are often overlooked but I think about the only place you can find them now is Pep Boys. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 23, 2012 Share Posted March 23, 2012 Factory is KYB I remember when I finally took them off my 95 Legacy it was etched in the side of the strut. Link to comment Share on other sites More sharing options...
