outdoorkindaguy Posted March 20, 2012 Share Posted March 20, 2012 So I just replaced the front bumper to my legacy and afterwards my left headlight seems dim and has a slow reaction when switching from low beam to high beam. So I went to change out the fuse, it was blown, and blew the next two I replaced it with. I replaced one and it blew just turning on the headlights, then I replaced the left headlight relay with a parts car one and the fuse and still the fuse blows just turning on the headlights. I'm not good with electrical jobs and am asking for help as too what to do for this problem. Link to comment Share on other sites More sharing options...
Rooster2 Posted March 20, 2012 Share Posted March 20, 2012 Recommend you check your headlight wiring for damage. It sounds like you may have accidently pinched wiring, or skinned off the insulation from wiring when you replaced the bumper. The result is that you have a wiring short circuit that is causing the fuse to blow. Link to comment Share on other sites More sharing options...
outdoorkindaguy Posted March 20, 2012 Author Share Posted March 20, 2012 YEP! I pinched red/blue against the horn mount while tightening the bolt. Thanks for the info! I thought it was the relay or maybe the radio since I had switched it, because you know I never mess up! Link to comment Share on other sites More sharing options...
Olnick Posted March 20, 2012 Share Posted March 20, 2012 outdoorkindaguy said: . . . because you know I never mess up! Welcome aboard, outdoor. You'll be right at home here! And congrats on finding the problem. Link to comment Share on other sites More sharing options...
