Suba_GL_87 Posted March 21, 2012 Share Posted March 21, 2012 where Trailer Hitch Wiring on my outback subaru 96? Link to comment Share on other sites More sharing options...
davebugs Posted March 21, 2012 Share Posted March 21, 2012 IIR LR taillight or below that is where the wireing for a 4 wire plug can be plugged in. No need to tap into individual wires. I've removed and sold several but never installed. Link to comment Share on other sites More sharing options...
mdjdc Posted March 21, 2012 Share Posted March 21, 2012 There is actually a plug in the trunk by the rear on the right, I think. Look around in there and you will find it. Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted March 21, 2012 Author Share Posted March 21, 2012 ya, i find from the rear driver light from the plastic box ...there is 6 code with small white/yellow connector? it's for wire connector trailer? also... i was looking for internet try to order hitch bar... but no drilling? so, i check under my wagon there have a 'rubber with black circle' (which can take off the rubber) for install hitch but there is big hole than i thought? it's normal or what. Link to comment Share on other sites More sharing options...
mdjdc Posted March 21, 2012 Share Posted March 21, 2012 If you want to put a hitch on you are going to have to drill two holes. The rubber covers an access hole to put the bolt into the frame rail, but you have to get the hitch up there first and then drill the bolt hole. Then fish the botl through the hole and bolt the hitch up there. The other bolt points are where the tow loops are. If you want t hitch cheap, I have one that I took off a legacy gt. It will fit yours with no trouble. The previous owner left the draw bar in the reciever so it has rusted in, but I am sure you can persuade it out. Let me know if you want it. Mike Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted March 21, 2012 Author Share Posted March 21, 2012 yea, i would like to used hitch, i dont care if it's rust on it. cuz i need tow by my boat. mdjdc said: If you want to put a hitch on you are going to have to drill two holes. The rubber covers an access hole to put the bolt into the frame rail, but you have to get the hitch up there first and then drill the bolt hole. Then fish the botl through the hole and bolt the hitch up there. The other bolt points are where the tow loops are. If you want t hitch cheap, I have one that I took off a legacy gt. It will fit yours with no trouble. The previous owner left the draw bar in the reciever so it has rusted in, but I am sure you can persuade it out. Let me know if you want it. Mike Link to comment Share on other sites More sharing options...
mdjdc Posted March 21, 2012 Share Posted March 21, 2012 GEt me your zip and I can get a shipping quote. How does 50 for the hitch sound? Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted March 22, 2012 Author Share Posted March 22, 2012 97701 mdjdc said: get me your zip and i can get a shipping quote. How does 50 for the hitch sound? Link to comment Share on other sites More sharing options...
