Moosen Posted March 23, 2012 Share Posted March 23, 2012 (edited) Is it okay to run for example a 140 and 135 main jets? 190 and 180 air jets? and 55 and 45 idle jets? Edited March 23, 2012 by Moosen Link to comment Share on other sites More sharing options...
Moosen Posted March 23, 2012 Author Share Posted March 23, 2012 Help? Trying to get my weber in this weekend Link to comment Share on other sites More sharing options...
desertsubaru Posted March 23, 2012 Share Posted March 23, 2012 Contact theses guys they will know. http://www.redlineweber.com/ or search this board. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 24, 2012 Share Posted March 24, 2012 Jetting is dependant on engine size, condition, altitude, and a variety of other metrics including how it's going to be used. There is no "wrong" way to jet a carb unless it doesn't do what you wanted it to do. Jets of differing sizes must often be used because the size of each barrel of a progressive carb is often different. In the case of the common Weber DGV series the primary is 32mm and the secondary is 36mm in diameter. GD Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted March 24, 2012 Share Posted March 24, 2012 As you can Read, ~► Here "...my BumbleBeast has 140 on Low Stage (Primary) and 162 on High Stage (Secondary) On the 32/36 Weber..." For more info, read that Thread on the Link above. Kind Regards. Link to comment Share on other sites More sharing options...
