Rear differential operation 4eat
can anyone tell me if on a 4eat rear diff if when I spin each tire should it spin the other? one will spin the other ie right will spin the left but left wont spin the right. this is on jack stands by hand.
hmmm, I can tell you on my wife's 03 H6 with weather package, the right rear will spin the left in the same direction (LSD).
however, I'm not sure I've tried it the other way. I will try it in April when I plan to do some maintenance. But, I'm not really sure I understand your question. Also, can you be more specific about the vehicle and what direction you expect the wheels to turn?
Someone else here may already know how to answer your question.
I have a 96 lego l 4eat. I think you do understand or are at least trying to and I really appreciate it! essentially if I put the car on jack stands with the car in p or off I can rotate one of the rear wheels and see the opposite rear tire spinning slightly less rotation than the tire I'm have my hand on. if I then go to the other side of the car and spin the opposite tire by hand the tire I was at first does not move. I can't remember exactly which is right and left that effect or doesn't effect.
Well, some folks say that after about 60-80k miles or so, the rear VLSD is worn out. Likely it depends on other factors like how often the car is on low-traction surfaces etc. Basically, the rear lsd wears out. Dunno why it would behave in an asymmetric manner though.
You do not have an LSD.
When you spin a tire on an open diff when the driveline is attached to something like a transfer case or clutch pack that is not engaged then the power will transfer to either the opposite wheel or the driveline - whichever has less friction.
Subaru rear diffs are hard like a coffin nail. Your rear diff isn't broken. If it was it would be making horrific noises and you would know....
I will check if the rotation gets transferred to the drive line. I'm glad it seems that rear diff failure is horribly evident because I have had to drive it around and it seems to spin consistently with no noise or vibration.
I was told there are mechanical parts like levers in the diff could some of this have stopped functioning due to abuse and not cause noise or vibration just none operation?
There are 6 gears and a few bearings in your diff. It's that simple.
No levers or magic going on.
When my rear diff failed it started out sounding like a wheel bearing, kinda. Then turned into a terrible awful noise. It was an ear retching squealing sound.
This happened with about 244,000 miles.
sweet I though it was about that simple. :clap: very pleased I don't have to replace my rear diff other than when I want to upgrade to an LSD.
I know I'm almost beating a dead horse but what could happen if say one or two of the gears on one side had teeth that were ground down from extended use?
no never I thought I might have felt some very slight binding a few days before installing the new parts but I think it was just extra line pressure from limp mode causing what I thought was torque bind, felt it only in the steering wheel. when driving, the car would corner fine and not lurch around as with actual TB but it was slightly harder to turn the car and would not idle itself in a circle.
one of the things that really threw me from the start about this car was the rear diff... my first car was a real FrontWD impreza with completely independent rear. when I started driving the lego I think I confused the presence of its non powered rear diff with full AWD. again I was not pushing it and under the impression my inspection mechanic had verified it had at least functional AWD. I have ridden in many manual subaru's but have never been carted around in a 4eat.
The ring and pinion gears?
They start making bad noises, they don't even have to be very worn to make bad noises. Here's a pic I took the other day when I took mine out.
It really doesn't work that way. The teeth are case hardened and once the outer surface of the gear teeth is compromised - failure of a complete and total nature will result almost immediately. If its not making horrific gnashing or howling noises or hasn't bound up completely.... It's fine. Seriously when a rear diff goes you will be dragging one or both wheels down the road as they will seize up.
there are a couple of possibilities here:
1/ you had a bad duty c (flashing AT Temp light) and torque bind. this means all the mechanical parts were in place and working before the repair and only the duty c was bad.
2/ you had a bad duty c (flashing AT Temp light) and NO binding, which means that at least some of the mechanical parts were not working properly.
in either case, it does not seem as though the repairs were done correctly. either the wrong parts, or not enough parts or an error in the process, or what ever.
it is hard to say since we did not drive the car before the repair. but it is for sure you do not have power to the rear wheels now, after the repair?
stupid question, how did you determine there is no power going to the rear wheels? you have probably already posted this but i just don't remember.
ps: the VSS will/ should throw a code if bad.
I asked the dealership to verify 10% power was going to the rear since then I did not have 4 jack stands only 2.
I put it on 4 jack stands in d or 1st, 1st has no effect as it should lock the rear more.
so if both of the vss are fine the tcu still wont output a specific code if the rear does not get drive?
the TCU only reports electrical faults in the trans. if there is a mechanical fault there will be no code.
the vss, either one, SHOULD throw a code if bad.
have you tried unplugging the TCU and checking the power to the rear then.
on an open diff with both wheels in the air, when you turn one wheel by hand, the other wheel should turn in the opposite direction. if it does not, then there is probably some kind of a load on the wheel that is not turning, either a dragging brake or a bad wheel bearing. but if the other wheel does not turn, then the drive shaft should be turning, and it will have less resistance than the other, dragging , wheel.
yes tried unplugging the TCU but I only drove the car I did not have time to put it on jack stands. I did not feel any binding what so ever.
if a diff like mine (4eat) was not being powered but just rotating along with the road could there be an underlying problem that is not detectable without torque being applied through its drive shaft?
It's almost impossible the diff broke in such a way that it won't transmit power to the wheels, and also didn't/doesn't make any really terrible awful noises.
And even with the 4eat (working properly) there's still some torque going to the rear diff. When mine was failing it would make noise when under load (either accel or decel). But if I put in the FWD fuse it went away because it was just freewheeling. It would make noise just cruising down the highway at 65. So it's mostly fwd just cruising along.
never heard of one. i have been driving a 95 AWD with no rear drive shaft for 40k miles, with no problems.
lol like I said in my other thread about no awd I just bought the car.... the diff oil that's in it was spotless with some shavings but who's to know what happened 100k prior did someone abuse this car? I paid what I though was a reliable source to check the car out before I bought it and he kinda let me down.
I'm learning and plan on doing it myself from here on out.
