0c5er Posted March 24, 2012 Share Posted March 24, 2012 Hey guys and girls, I'm new here, but figured this was as good a question as any to serve as my first post. First of all, I drive an '06 Impreza 2.5i. On Thursday while at work my car died and I had to get someone to give me a jump. After work when I went to drive home it started up alright, and I made it back home (35 miles). But then yesterday I went to go to the store and it almost didn't start on me (barely turned over) so I knew it was time to go get a new battery. I took it down to Advance Auto and got a battery and had them throw it in there for me. After about 5 minutes of driving with the new battery in the CEL came on and the car started randomly stalling out while shifting. Not a hard stall more like it just shuts off completely. I took it back and the code coming up is p0506. I checked and I don't see any loose vacuum hoses or anything like that but at the same time I'm no mechanic. I just don't see how this could happen after a battery change. I've had this car for 3 years and I've never had a single problem until this. Anyone know what the root cause of this is or what I should do? Help please! Thanks! Link to comment Share on other sites More sharing options...
Rooster2 Posted March 24, 2012 Share Posted March 24, 2012 bad battery cable going to the starter, or bad alternator Link to comment Share on other sites More sharing options...
Olnick Posted March 24, 2012 Share Posted March 24, 2012 Welcome aboard! P0506 - Idle Air Control System RPM Lower Than Expected A vacuum leak An air restriction in the intake air path or exhuast A faulty positive crankcase ventilation (PCV) valve Damaged/failed/dirty throttle body Internal engine problem Failed PCM When was your air filter last replaced? Your IACV (Idle Air Control Valve) might be gunked up and need cleaning. New PCV valve might help--and clean out any gunk in the hoses leading to it. Good luck. Link to comment Share on other sites More sharing options...
ivans imports Posted March 24, 2012 Share Posted March 24, 2012 Alt main fuse hooked jumpers wrong ? fuse is a 70-100 amp in under hood fuse box check voltage at batt running should be 14.20 but no more than 15 and no less than 12.50.My gess is its not charging right. Link to comment Share on other sites More sharing options...
Gloyale Posted March 24, 2012 Share Posted March 24, 2012 Engine main connections are right there behind the battery. Perhaps the guy disconnected one? or maybe the hold down is pinching a wire? I'd double check the battery install. Link to comment Share on other sites More sharing options...
0c5er Posted March 24, 2012 Author Share Posted March 24, 2012 I took the battery out and left it out for about an hour. Then I put it back in, let the car idle for about 15 minutes, and it seems to be fine now. It seems like it's still idling lower than it should be, but it's running just fine and the CEL/stalling have stopped. I'm guessing it was nothing major. I will update though if something else happens. Thanks for your help! Link to comment Share on other sites More sharing options...
jc50942 Posted March 24, 2012 Share Posted March 24, 2012 ive come across this a couple times...for me it was always that little secruity button that is taped under the dash. Link to comment Share on other sites More sharing options...
