I'm kinda in the same boat. IIRC, replacement belts should be 105k. You can remove the driver side timing cover to inspect the belt but I would probably question the remaining life in the tensioner and idler pulleys more than the belt itself, not to mention the WP and resealing the oil pump. congrats on having a 99 forester with 177k miles. 180k sounds like a nice round number to remember that the front end was done. Moon shot...It's a subaru thing:D
I am kind of wondering how durable the belts are too. I have no idea the mileage of my belt on my newly purchased impreza with 165k miles. Visually its a little shiny with some tiny cracks in it, but I have heard they almost never break unless a bearing in a pulley goes. How true is this?
sounds like we need a timing belt party:drunk: . but seriously, if you can't confirm that the belt has been replaced, 165k is waaay overdue. may as well order a kit with tensioner and pulleys because when you get into it if the bearings sound like a skateboard-they also need to be changed. cracks in TB are almost never a good sign. just my .02 (adjusted for inflation).
IMO if you dont know the milage...replace it..and alll the pulleys and water pump. It will end up saving you the trouble of doing valves down the road if it does break. Ive seen too many ppl get rid of nice cars that they liked cause they didnt keep up on the maintenance and "took a chance". Just my two cents.
When in doubt do the belt. And I always do everything that touches the belt.
In your case it's up to you on crank and cam seals, oil pump Oring and screw tightening.
I do accessory belts, coolant, plugs, fuel filter, oil & filter and then it's done for a while.
  98obster said:
^^^ very sound advise. On a similar topic, is it possible to service the oil pump without removing the belt?
NO. It's behind the cogged end of the crank behind the crank pulley/harmonic balancer.
Infact to me it dictates a new crank seal too. ALong with the oil pump Oring and ultra grey (no gasket) and check those screws on the back of the pump!
Well I just dont have the time to replace it right now :( Bearings sound fine, motor is actually pretty whisper quiet. they are hairline cracks, but I agree never a good sign. Just wondering how bad it actually IS. maybe I will go take a quick cellphone pic.
IIR just a belt ranges 35-50 for Dayco for 2.2 to 2.5 belts.
You're asking those idlers to go an awful long time.
The labor is virutally the same.
But to each their own. I understand being on a budget too. But a car is kind of important. To get a person to work and food. So I have a tendency to cut back on car maintenance last.
Looks worse on pic than in person since its so close up :(
  murphsubaru said:
I am not sure it's worth spending $500.00 on a timing belt change on a car with high mileage and rust. Maybe I should wait until the belt has 105,000 miles.
Can get it done independently for about half that probably. very important on a post 97 model, not as much on the non interference pre 97 models.
i had one last week that looked just like that...didn't break, but the teeth on the backside of the belt were coming off...crank was turning but the cams were not.
do you have a pic of the tooth side? broken/cracked teeth=broken TB. Man, I want to drive to where you are and change that belt now :eek:
not sure what your year is but:
http://www.ebay.com/itm/03-97-98-2-2L-EJ22E-Subaru-Impreza-Legacy-SOHC16V-Timing-Belt-Kit-Water-Pump-/260923356471?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ASubaru&vxp=mtr&hash=item3cc03e7537
Edited by 98obster
Yikes!! That looks bad. If $200 for a belt is too much, just stop driving it. When that breaks it's gonna cost a lot more in valves and gaskets.
At this point you'd be better off replacing the belt with a cheap one, and replacing any really bad idlers than letting it be. I probably wouldn't drive an interference engine with a belt that bad across town.
When I replaced my timing belt (at about 102,000 miles), the rubber was pristine. The only visible deterioration was that the maker's name and inked-on timing marks had been worn off.
Your photo looks pretty bad to me. All those surface cracks can let contaminants into the fabric inside the belt. I would change it ASAP.
  • 3 weeks later...
chiming in a little late on this one,
but i did a lot of research on belts a while back when
i got my kit for my 95.
the contitech kits are supposed to be the best and
have the high-saturated nitrile (HSN) belt instead of
high-temperature neoprene (HTN) belt, which is what
you'll normally find. also, i have used the cheaper ebay
kits but i think they are cheaper knock off pulleys and
water pump, where the ones that come with contitech
(continental of old) are at least oem or better. (supposedly,
but they do look very well built and the wp that came with mine
is an Aisin which I believe to be original manuf.
(strange thing is, i was told here on usmb a long time ago to
look for the german belts by Conti, but when I got my HSN belt
it says Made In Mexico, but I guess the tech is what's important.)
i actually was surprised how much tech went into the belts.
you might think that all belts, i mean across vehicles, would
pretty much be the same, but there's a whole science to
how they make the tooth shape, for example, and the same
manuf. may make many different tooth depths, width, angles
etc depending on vehicle co design. So, those cracks may mean
not only that the belt could break, but that it has more play
lengthwise and affect contact with the teeth, leading to more
breakage potential other than just snapping.
i forget where i found it, but i used to have a whole catalog
online where they had the actual shapes of the belt teeth, depth,
angles, etc.
but if you pick around here you'll get an idea:
http://www.contitech-usa.com/
lots of info there.
ps--hey! i found it! if you go into the "media" page of this site:
http://www.contibelts.com/prod_tbeltkits.asp
they have a real big pdf that has the shapes etc.
not that anyone's that into belts...
:lol:
'97
In the case of timing belts, we always say to err on the side of caution. If the "recommended interval" is 105,000, do it at 90,000. A belt is a lot cheaper than a new engine. (Even if it is interferential.) Getting stranded due to a shredded belt sucks. And tows aren't cheap either!
Here in Colorado, with our extremes of hot and cold, dryness, etc., rubber takes a beating a lot faster than, say, Vancouver.
Emily
  • 4 weeks later...
Actually the underside of the belt looks pretty good, no cracking that I can see. still going after another month and a half, but hoping to get around to this soon.
