blinkytoo Posted March 25, 2012 Share Posted March 25, 2012 My 2000 Outback need new rear struts. It has some squeaks when going over bumps. I found some struts on an 2001 Outback in a junk yard. How hard is it to take them out in a junk yard setting? What tools do I need? The tires are off the wreck so it has good access. I am no mechanic but I am handy. Link to comment Share on other sites More sharing options...
987687 Posted March 25, 2012 Share Posted March 25, 2012 19mm wrench and socket for the bottom two bolts. Probably want a breaker bar and cheater bar to get those loose. They can be tight. I think it's 12mm nuts on the strut top. It's pretty easy, it's just getting the bottom bolts out can suck. Link to comment Share on other sites More sharing options...
98obster Posted March 25, 2012 Share Posted March 25, 2012 i would include in your kit: PB blaster, vise grips, large flat head screwdriver. sometimes it is easier to cut through the brake line bracket and bend it back to free the brake line from the strut, I just ziptie after I install, ymmv. Also, use a 6 point 19mm socket, not 12 point, or use risk rounding the nut. also, rachet and open end 19mm wrench are helpful. Link to comment Share on other sites More sharing options...
987687 Posted March 25, 2012 Share Posted March 25, 2012 You should throw away all 12-point sockets They make more of a mess of nuts. My favourite junk yard tool EVER? BATTERY POWERED SAWZALL!!! zzz If something doesn't want to come apart, cut it out. Then when you have it home on the bench you can extract the part you wanted. Link to comment Share on other sites More sharing options...
danbennett2u Posted March 25, 2012 Share Posted March 25, 2012 987687 said: You should throw away all 12-point sockets They make more of a mess of nuts.. Messy nuts is not a good thing. Link to comment Share on other sites More sharing options...
ocei77 Posted March 25, 2012 Share Posted March 25, 2012 (edited) 987687 said: You should throw away all 12-point sockets .... except the 14mm one for head bolts! Since he's getting it out of a junker, he can just cut the brake lines if need be O. Edited March 25, 2012 by ocei77 add Link to comment Share on other sites More sharing options...
987687 Posted March 25, 2012 Share Posted March 25, 2012 ocei77 said: except the 14mm one for head bolts!Since he's getting it out of a junker, he can just cut the brake lines if need be O. HAH I almost mentioned 14mm for head bolts. I actually had to go out and buy one when I first did head gaskets. If you're taking the block apart you need 12mm 12point sockets too. Link to comment Share on other sites More sharing options...
jp98 Posted March 25, 2012 Share Posted March 25, 2012 Remember also that you are taking the spring also. Don't try to remove the strut from the spring without a spring compressor. Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 26, 2012 Share Posted March 26, 2012 12 point sockets are useful in certain aspects. For hammering a smaller socket onto a rounded fastener they work much better than 6 point sockets. For the matter at hand, big breaker bar and a cheater pipe. Those lower strut bolts can be really tight, and it's that much worse if theyre rusty. Link to comment Share on other sites More sharing options...
