no oil pressure?
So i just put in my weber carb and everything is good, still need to rejet (running a tad rich)
but it says i have no oil pressure. I think the cable for the sensor came unplugged but im not sure. Where is the sensor and what does the wire look like/ where does the wire come from. I have a spare wire hanging out over by the oil cap but i cant find where it goes and the oil pump (or what i think is the oil pump) down by the oil filter already has a wire plugged into it?
On the oil pump end, the wire is connected to the green part of the oil pump pictured here:
And in the car the oil pump is located as seen pictured here:
Above you can see there are two connection points on the oil pump.
The one on the green part is for an oil pressure gauge (Think that's what you need to look at)
The one above and to the left of that is for a dummy light.
both of those are plugged in?! and it still shows no pressure
