2001 OB Automatic with Trans Problem
Need some advice. Just bought a 2001 OB with auto trans. 217K miles.
Moves in D and R, but makes horendous knashy clicky noise under pressure. PO put in two new axles 6 months ago. Today, I was barely able to drive it up on a trailer in R. Seems worse (noisier, when turning wheels to steer) PO said cars trans was whinning for about 3 months before it made the big nasty noises it makes now.
He drove it almost an hour each way for commuting beofre this.
It sounds like a bad front diff. Or could the axles have been put in wrong and just went to hell?
Ideas welcome.
I will check in the AM. If the fluid level is low, then then the front diff is probably roasted then correct? And I understand if that is the deal, then a new used trans is probably better then correct?
Unsure of the mileage. I got it from a guy off craigslist a while back. Ended up going with an 03 trans to avoid the delayed forward engagement issue and had a little more history on that trans.
The 2000 one is sitting in a few pieces in my garage. I pulled the rear and pan so i could get a good look at things. Would need some RTV and about 15 minutes with a socket wrench to put it in one piece. Checked for any metal shavings etc. Looks good to me (a novice) $100 and it's all yours.
