3Pin Posted March 27, 2012 Share Posted March 27, 2012 Need some advice. Just bought a 2001 OB with auto trans. 217K miles. Moves in D and R, but makes horendous knashy clicky noise under pressure. PO put in two new axles 6 months ago. Today, I was barely able to drive it up on a trailer in R. Seems worse (noisier, when turning wheels to steer) PO said cars trans was whinning for about 3 months before it made the big nasty noises it makes now. He drove it almost an hour each way for commuting beofre this. It sounds like a bad front diff. Or could the axles have been put in wrong and just went to hell? Ideas welcome. Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 27, 2012 Share Posted March 27, 2012 Check fluid? Level low? PO might have pulled the axle stubs out and chewed the seals up, then all the fluid leaked out. Link to comment Share on other sites More sharing options...
3Pin Posted March 27, 2012 Author Share Posted March 27, 2012 I will check in the AM. If the fluid level is low, then then the front diff is probably roasted then correct? And I understand if that is the deal, then a new used trans is probably better then correct? Link to comment Share on other sites More sharing options...
AdventureSubaru Posted March 27, 2012 Share Posted March 27, 2012 The diff could be okay. It has a separate fill tube than the trans itself. The long dipstick on the drivers side will be for the trans and takes ATF. The smaller dipstick on the passenger side is for the diff which takes gear oil. Link to comment Share on other sites More sharing options...
3Pin Posted March 27, 2012 Author Share Posted March 27, 2012 I just bought it in Lake Geneva. LOL Link to comment Share on other sites More sharing options...
AdventureSubaru Posted March 27, 2012 Share Posted March 27, 2012 Post up a pic if you can. I've probably seen it around. I have a spare trans from an 2000 outback should you end up needing parts. Link to comment Share on other sites More sharing options...
3Pin Posted March 27, 2012 Author Share Posted March 27, 2012 Thanks, that might work. How many miles on the trans and how much if you would consider selling the whole thing? Link to comment Share on other sites More sharing options...
AdventureSubaru Posted March 27, 2012 Share Posted March 27, 2012 Unsure of the mileage. I got it from a guy off craigslist a while back. Ended up going with an 03 trans to avoid the delayed forward engagement issue and had a little more history on that trans. The 2000 one is sitting in a few pieces in my garage. I pulled the rear and pan so i could get a good look at things. Would need some RTV and about 15 minutes with a socket wrench to put it in one piece. Checked for any metal shavings etc. Looks good to me (a novice) $100 and it's all yours. Link to comment Share on other sites More sharing options...
3Pin Posted March 27, 2012 Author Share Posted March 27, 2012 What else can you tell me about it? Is it a known working unit? I hate to put it in and then have to take it out. How long has it been sitting? Thanks Link to comment Share on other sites More sharing options...
Caboobaroo Posted March 27, 2012 Share Posted March 27, 2012 Sounds like the front diff is gone. Recently did one in a 2000 OBW with a new ring and pinion and seals... Link to comment Share on other sites More sharing options...
3Pin Posted March 28, 2012 Author Share Posted March 28, 2012 Out of curiosity, How much time and $ was it to rebuild it? Link to comment Share on other sites More sharing options...
AdventureSubaru Posted March 28, 2012 Share Posted March 28, 2012 It was sold to me as a running builder. One of the bolts was broken where the linkage bolts up. The front diff should be fine. Link to comment Share on other sites More sharing options...
Caboobaroo Posted March 30, 2012 Share Posted March 30, 2012 I think I had close to 10 hours plus the cost of parts. Thinking it was right around $1500. Link to comment Share on other sites More sharing options...
3Pin Posted March 31, 2012 Author Share Posted March 31, 2012 Adventuresubaru, I ended up putting a 2001 trans in there after thinking a while about the delayed engage problem on the 2000 trannies. Thanks for the offer though. Link to comment Share on other sites More sharing options...
