Struts, springs , and lift
splitboarder
I pulled the trigger on a 6 inch SJR 6 inch lift last night . I have some questions about struts and spings though
I have a 1997 legacy L wagon. It sit LOW as it is. I want to run 205/75 r 15 or 205/75/r16 on it with no fender rub. ( I may have to go with 215 instead )
Should I keep the stock sturts and springs ...or should I install outbach struts? And if I go with outback struts do I need outback spings also? A 97 outback- is it a legacy or impreza ? or do I go with 1999 ?
will outback struts bolt right up or do I need to drill new holes/ modify anything?
Thanks. Im a bit confused right now
Edited by splitboarder
Use the Outback springs and struts. With the lift kit you won't have to redrill anything.
You will be able to run a 215 with no fender rub with the lift kit as well. Install the kit prior to purchasing new tires because you maybe able to go bigger. I run 215/75/15 with just Outback struts and springs. The only rub I get is on the inside of my wheel wells during tight turns.
When I look for struts on the web at internet sites (like patrs geek) in the year 1997 I only get three choices. Legacy, Impreza and SVX. They dont show a difference or, dont have an "outback" choice . Do I have to go to a 1999 year model?
Get 99 LEGACY OUTBACK struts.
235/75/15 will be as big as you can go, unless you get wheels with a deeper dish. With the Subaru wheels, the tire will hit the spring perch in the rear if any bigger.
215/75/15 = yes
215/75/16 = no
  splitboarder said:
Thanks Gloyale
You hit the nail on the head. Its 1999 that is different between the two. 1997- no difference
Well, there was an actual difference on the cars in 97.....I guess just not in the catalog of where you are looking.
spent a while looking at Oriely's website( easy to go between years and models) , entering in each year then each type. legacyL ,brighton ,outback and outback limited ( 1999). Part numbers were the same for 97,98 but 99 the outback were different. Funny thing, even the 97 legacy and the 99 legacy had the same part numbers
