maniac Posted March 29, 2012 Share Posted March 29, 2012 (edited) bought it like it and want to make it right. please any feed back is appreciated. my only 2 problems when the car is cold i have to give it a little bit of gas while starting it then hold it for about 5 seconds or so, other wise it just wants to stumble and not start, I believe this is a tps problem, can it be cleaned? or switched out with my spare 91 legacy parts car that doesn't have the starting issue? or just buy a new one? my other problem I have is my brights do not work it just shuts off the regular lights. checked the fuses, changed the bulbs, maybe bad wiring or bad switch? maybe some thing my parts car can be switched out? Edited March 29, 2012 by maniac Link to comment Share on other sites More sharing options...
WoodsWagon Posted March 29, 2012 Share Posted March 29, 2012 Probably a dirty idle air control solenoid. You can try spraying carb cleaner in to clean it, pull off the 1" black rubber hose that goes to the IAC which is on the passenger side of the throttle body and hose the valve inside down. You may have to take the whole valve off the intake to clean it properly. Headlights could be the switch or the relay, which I think is under the dash on those. Do the high beams work when you pull the switch into the "flash to pass" position? Link to comment Share on other sites More sharing options...
maniac Posted March 29, 2012 Author Share Posted March 29, 2012 when I switch to the brights it just shuts down the lights completely no head lights at all . Link to comment Share on other sites More sharing options...
WoodsWagon Posted March 29, 2012 Share Posted March 29, 2012 The headlight switch has 3 positions. Low beams, high beams, and a springloaded flash high beams position. What does it do in the springloaded position? Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 29, 2012 Share Posted March 29, 2012 Starting issue could be the IAC or a failed engine temp sensor. Its telling the ecu the engine is warm so it doesn't get enough fuel to start properly. Simple things can help as well. Get new plugs and wires, new PCV valve, air and fuel filters. Check for split/broken vacuum hoses as well. Link to comment Share on other sites More sharing options...
maniac Posted March 29, 2012 Author Share Posted March 29, 2012 1.first position normal lights work fine.2 pull back for spring load high turns lights out completely let go to normal lights come back on, 3.push forward for high and shuts lights out completely, Link to comment Share on other sites More sharing options...
95legwagon Posted March 30, 2012 Share Posted March 30, 2012 sounds like a bad column switch imho..... not too hard to replace just a pita lol.... also check the grounds for that circuit....subaru has been known to paint before they attach their grounds to the frame....thus bad grounds everywhere Link to comment Share on other sites More sharing options...
AdventureSubaru Posted March 31, 2012 Share Posted March 31, 2012 Try the other things listed. A bottle of Seafoam can work wonders on older/high mileage cars. Clears things out... and smokes your neighbors out of their homes in the process. Link to comment Share on other sites More sharing options...
maniac Posted April 1, 2012 Author Share Posted April 1, 2012 funny I just picked up a can of seafoam yesterday Link to comment Share on other sites More sharing options...
