I found a broken synchro blocking ring? , Where to get new one?
Got my input shaft taken apart and the synchro blocking ring? for the high range (I think) is bent and cracked from someone beating on the input shaft trying to get the holding plate to sit.
Anyhows , where and can I get a new one? or is it a totally vital part? (I know kinda a dumb question and would probably make it impossible to shift into high range without turning engine off or something by not having it on)
This is in a EA82 5mt D/R
Here's where I took off the blocking ring
Here's the blocking ring alone on my counter
And ignore the hammer , it was involved in only getting the pin outta the dual range shift lever.
