02 wrx steering wheel swap
96LegacyEJ22
I happen to like my "fugly" wheel.
But I digress, did you get the plugs for the airbag and cruise/horn wiring with the wheel?
The airbag wiring is not something you want to screw up. It should be separate from the horn and cruise wiring, and probably has a yellow plug. You WILL need the proper plug for the airbag module if the one in the car doesn't fit. The others you can solder together, but you should't solder wires directly onto an airbag module.
