The sender is probably shot. My buddies truck has a bad sender, when you fill it up the gauge reads 1/4 tank. It never goes above that or below the empty line, you can drive 150 miles with it sitting on 1/4, then it starts to drop, and when it gets to empty you fill it up and it takes 18 gallons. 20 gallon tank. Gauge goes back up to 1/4 and stays there.
That would explain what happened on Thursday it was at 1/4 and I went to pass someone and I remember saying in the car WTF?? It went from 1/4 to Empty and that was that..
I know $40 of gas should have the gauge reading just about spot on at 1/2 a tank.
So how much does the dealer kill you on the fuel sender? $300?
I hear some say use techron I still have a bottle left I think but I can't see how it will help all that much.
9 Gallons in the tank
well checking the price at a somewhat local place it's $149 for both the sending unit and sub unit which is not bad
Edited by 1-3-2-4
indeed it is a chunk of change..... but also i have read that this is quite a common thing to go wrong with our soobs....mine acts funny also but hasnt done this yet lol...... try F and S auto parts..... they have a website and are located in roxbury ct. just went there yesterday..... great junkyard and they have everything you would ever need for a soob
My post apparently didn't post.
I have a half dozen of these sets from scrapped cars. They have been stored for a few years though.
This is a common problem.
FYI usually you get a LOT of fuel smell if you don' t get the new rubber gaskets. If you're going to the dealer to get the pumo/sending units get both gaskets too.
just a heads up i've noticed the impreza's with the older type cluster (94-97)had a cluster issue that would cause this. The 3 screws on the back would loosen up and cause it to stick on E. I went through a couple sending units and junkyard clusters til i figured this out lol
