scoobyclimbs Posted June 9, 2012 Author Share Posted June 9, 2012 Nice! Just out of curiosity, what did the King springs run? And they lift roughly 1.5" right? about $430 set of four springs, 1.5" is correct. Link to comment Share on other sites More sharing options...
subaruman5 Posted June 10, 2012 Share Posted June 10, 2012 digging the black grille.. Link to comment Share on other sites More sharing options...
cmiller Posted June 10, 2012 Share Posted June 10, 2012 The Fozzy is looking good! Link to comment Share on other sites More sharing options...
scoobyclimbs Posted June 11, 2012 Author Share Posted June 11, 2012 Many hours of washing , prep, primer, painting 5 wheels are done... Link to comment Share on other sites More sharing options...
subaruman5 Posted June 11, 2012 Share Posted June 11, 2012 Looking good:Flame: Link to comment Share on other sites More sharing options...
AdventureSubaru Posted June 11, 2012 Share Posted June 11, 2012 Looks good! You upgrading the tires now that you have more clearance? Looks like plenty of space inside those fenders. Link to comment Share on other sites More sharing options...
scoobyclimbs Posted June 11, 2012 Author Share Posted June 11, 2012 Looks good! You upgrading the tires now that you have more clearance? Looks like plenty of space inside those fenders. Hankooks dynapro M/T's 215/75R15's Link to comment Share on other sites More sharing options...
scoobyclimbs Posted June 12, 2012 Author Share Posted June 12, 2012 Got my kings springs and 1" strut spacers, eibach camber bolts.. Link to comment Share on other sites More sharing options...
subaruman5 Posted June 13, 2012 Share Posted June 13, 2012 what size tyres were on your GL? Looking at maybe upgrading to those Hankook dynapro:) Link to comment Share on other sites More sharing options...
scoobyclimbs Posted June 13, 2012 Author Share Posted June 13, 2012 what size tyres were on your gl? Looking at maybe upgrading to those hankook dynapro:) 235/75r15 Link to comment Share on other sites More sharing options...
scoobyclimbs Posted June 14, 2012 Author Share Posted June 14, 2012 half lifted...I did the rear strut lift... I have 12 1/4" at pinch weld in front of the rear tire. The rear diff I have 11 1/2" now... I'll finish the front tonight.. Link to comment Share on other sites More sharing options...
scoobyclimbs Posted June 15, 2012 Author Share Posted June 15, 2012 (edited) the rear was done using '03 SG struts, kings springs KSRR-33, Paranoid fabrications 1" strut spacers(HDPE) '02-07 impreza. Note: some chamfering required to fit strut tops. camber bolts from primitive Lower position.. Front lift is stock struts, king springs KSFR-32, primitive 1/2" strut spacers(HDPE) stacked. I now have 12 1/2" at the pinch welds(factory jack up points ) 11 1/2" rear diff. 9 3/4" at front skid plate. I also swapped my cargo basket from the outback (temporary) Edited June 15, 2012 by scoobyclimbs Link to comment Share on other sites More sharing options...
bratman18 Posted June 15, 2012 Share Posted June 15, 2012 Looks good! How tall are your tires in inches? Link to comment Share on other sites More sharing options...
scoobyclimbs Posted June 16, 2012 Author Share Posted June 16, 2012 Looks good! How tall are your tires in inches? They are stock tires 205/70R15 I have a set of 215/75R15 bfg a/t's (27.7" dia) I can bolt on now.. Mud terrains will be on soon enough.. Link to comment Share on other sites More sharing options...
bratman18 Posted June 16, 2012 Share Posted June 16, 2012 They are stock tires 205/70R15 I have a set of 215/75R15 bfg a/t's (27.7" dia) I can bolt on now.. Mud terrains will be on soon enough.. Yeah I thought they looked a little small, so that makes sense. Those 27.7's would be real close to the rear struts, even with the SG rears. Mine measure a hair over 27.5 and there isn't much room at all. I'm sure with the right wheel they will be all good though. Link to comment Share on other sites More sharing options...
cmiller Posted June 16, 2012 Share Posted June 16, 2012 Looks great! Link to comment Share on other sites More sharing options...
bratman18 Posted June 16, 2012 Share Posted June 16, 2012 You should see about moving this to the members ride section! Link to comment Share on other sites More sharing options...
AdventureSubaru Posted June 16, 2012 Share Posted June 16, 2012 You should see about moving this to the members ride section! x2... My car should head over there as well. Link to comment Share on other sites More sharing options...
superu Posted June 18, 2012 Share Posted June 18, 2012 Many hours of washing , prep, primer, painting 5 wheels are done... THAT is going to look SIIIICK with the kings!! Might need a tint too Link to comment Share on other sites More sharing options...
superu Posted June 18, 2012 Share Posted June 18, 2012 the rear was done using '03 SG struts, kings springs KSRR-33,Paranoid fabrications 1" strut spacers(HDPE) '02-07 impreza. Note: some chamfering required to fit strut tops. camber bolts from primitive Lower position.. Front lift is stock struts, king springs KSFR-32, primitive 1/2" strut spacers(HDPE) stacked. I now have 12 1/2" at the pinch welds(factory jack up points ) 11 1/2" rear diff. 9 3/4" at front skid plate. I also swapped my cargo basket from the outback (temporary) Umm, YEAH!!! Might need a camber kit for the rear too, looks a little caddywompuss. Me thinks you may consider a touch of driveline lowing... Doesn't all that push you a touch over 2" greater than stock? Looks awesome G! the tires are gunna be full sweet sickness! Link to comment Share on other sites More sharing options...
cmill189 Posted June 18, 2012 Share Posted June 18, 2012 What do the CV's look like? My Outback has 10" at the diff and the CV's look like their lives will be considerably shorter. Link to comment Share on other sites More sharing options...
scoobyclimbs Posted June 18, 2012 Author Share Posted June 18, 2012 (edited) Umm, YEAH!!! Might need a camber kit for the rear too, looks a little caddywompuss. Me thinks you may consider a touch of driveline lowing... Doesn't all that push you a touch over 2" greater than stock? Looks awesome G! the tires are gunna be full sweet sickness! I just installed it with rear camber bolt as well ..I just head down to the alignment shop right after.. I just took the pics as I had just fin..the lift and it was around the corner of the shop..as the sun was setting... cv's are not an issue...only at 3"lift will you have problems..All the aussie folks can verify on www.offroadsubarus.com The driveline is at stock level.. the diff. hasn't changed it's relationship..only the cv's (I'll assume that's what you were addressing..) my outback has the same lift of 2.5" and zero issues..for years now.. Edited June 18, 2012 by scoobyclimbs Link to comment Share on other sites More sharing options...
bratman18 Posted June 18, 2012 Share Posted June 18, 2012 I immediately went through one front cv after my 2" lift, and now the other is making noise. Both factory Subaru axles too. Hopefully you have better luck than I did! Link to comment Share on other sites More sharing options...
scoobyclimbs Posted June 20, 2012 Author Share Posted June 20, 2012 (edited) a couple short vids taken by my 8yr son...as I was clearing blowdown out to get to this awesome campspot.. @ Mt.Hood . No one had set foot there since winter.. Who needs an axe or saw..? It's the new way to do "forest'er" management.. click on the first two pics to view vids. Edited June 20, 2012 by scoobyclimbs Link to comment Share on other sites More sharing options...
scoobyclimbs Posted June 22, 2012 Author Share Posted June 22, 2012 wheel/tire swap from my outrback w 215/75R15 bfg a/t no rubbing at full lock.. I have 13 1/2" at the body pinch welds and also at the rear diff. 10 1/2" at the lowest part of my front skidplate. Link to comment Share on other sites More sharing options...
