The FNG Posted April 11, 2012 Share Posted April 11, 2012 Can someone please explain this part--I am losing air out of it and it is making my engine stall out. It is located on the passenger side head and goes from the head to the intake. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 11, 2012 Share Posted April 11, 2012 (edited) EGR Pipe... Next to the EGR Valve on the intake Manyfold. I Don't understand the question Clear, Do you have Vacuum Leak? Edited April 11, 2012 by Loyale 2.7 Turbo mispelled word Link to comment Share on other sites More sharing options...
desertsubaru Posted April 11, 2012 Share Posted April 11, 2012 That is the EGR tube. Tighten the side thats on the intake because its causing an intake Vacuum leak. Link to comment Share on other sites More sharing options...
The FNG Posted April 11, 2012 Author Share Posted April 11, 2012 The end of the pipe got kinda screwed up and it won't seal I guess. It won't tighten any farther and I don't want to strip the threads. I guess I will try to locate a new one. I need to redo my intake manifold gaskets anyway. Thanks for the help! Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 11, 2012 Share Posted April 11, 2012 Why don't you just Close it and Forget the EGR? Do you Need to Pass Emmissions? Because the EGR Design is not Healthy for the EA82 and Subaru Knew that... That is Why the Latest (Third Gen) of EA82 Heads came Factory without the EGR Passages. I Closed the EGR Stuff on my BumbleBeast's intake Manyfold... (To see Pics, Click on my Avatar and Scroll down to Find my Weber Carb Swap Thread) ...and the Engine performs Somehow Better without it. Kind Regards. Link to comment Share on other sites More sharing options...
The FNG Posted April 11, 2012 Author Share Posted April 11, 2012 I have read a few threads that have said the EGR is good and that the EGR is bad. If I could block it off and trick the computer into thinking all was ok without any negative performance, than I would consider that, but at this point, I am still skeptical. Bumblebeast, I have a TBI or fuel injected engine and I don't think I will be going to do the weber swap, but I will have a look at how you bypassed the EGR in that thread. Link to comment Share on other sites More sharing options...
ivans imports Posted April 11, 2012 Share Posted April 11, 2012 Combustion is esacpeing from head bolts creaps through the head studs and comes out those bolt holes if you took head off you will find that head gasket was leaking into head stud a retourque of heads may help or headgasket Link to comment Share on other sites More sharing options...
desertsubaru Posted April 12, 2012 Share Posted April 12, 2012 Combustion is esacpeing from head bolts creaps through the head studs and comes out those bolt holes if you took head off you will find that head gasket was leaking into head stud a retourque of heads may help or headgasketDid you drink to much when you wrote that. LOL:drunk: Those empty bolt holes have nothing to do with his problem. You can clearly see that the EGR pipe is not threaded in thus causing a Vacuum leak and also expelling exhaust gas around the threads. Link to comment Share on other sites More sharing options...
The FNG Posted April 12, 2012 Author Share Posted April 12, 2012 I kinda thought the same thing :rolleyes:But the issue is not the threads either, they are tight as can be. The air is escaping from between the pipe and the threaded nut. I never really thought much about it when I did my head gaskets, but I noticed the pipe looked like someone had ground it down in the past since there was hardly enough of a flange to keep the nut on. I am going to replace it anyway and I should have one by tomorrow. Link to comment Share on other sites More sharing options...
desertsubaru Posted April 12, 2012 Share Posted April 12, 2012 Looks cross threaded to me. Link to comment Share on other sites More sharing options...
