LSD question
Ok, I've got this info for an LSD. Is it right and will it fit my Loyale with a 5spd manual 3.90 gears?
rear diff from a 04 wrx. 85k miles, pulled from a salvaged running driving car.
will fit all 2002-2005 3.90 5 speed wrx's. will not fit the 4.11 automatics. $100
Edited by The FNG
No, your rear axles need stubs on the rear diff to fit; the WRX doesn't. Is it a VLSD or true LSD diff? Also, I think you need a 3.900 ratio and the WRX is usually a 4.111. Price is very good if it's a true LSD; you could use the clutch pack in the diff and install it in your current open diff.
I suppose I need more info on it then. I was super stoked on the price. If I am correct, there should be a nameplate on the back of it that would specify more info (just like on my Loyale). If there is no nameplate, then how would I be sure exactly what the ratio is, if it is really an LSD (it doesn't have stubs to rotate, just female holes), and what type of LSD it is?
Thanks again.
