Loyale flexplate cracking
I am having issues with flex plates on my 93 Loyale. It has 185k on it and the second one I replaced just cracked. Looking for help on whats causing it and if there is an after market replacement. :banghead:
Edited by DukeGB
Sounds like a misalignment between the transaxle and the engine. Did you notice if the two locating pins are still in the bellhousing? Check the bellhousing for any signs of cracking or damage.
Also check the end play on the crank, maybe the engine bearings are hosed.
